Overhead console loose from headliner
Old Oct 19, 2010 | 06:00 PM
mynewtls's Avatar
The plastic part that has the dome lights, the switch for the moon roof/garage controls came loose from the headliner. Its connected to the rear view mirror but the other end is very loose, hanging just a little. I pushed it back up and down the sides thinking it just came out of a clip but with no luck.
Old Oct 20, 2010 | 09:11 PM
U3A6's Avatar
The roof console (interior colored) housing is bolted to the roof with (4) 10 mm hex head bolts. The black map light assembly is clips into the roof console housing. The moonroof switch clips into the map light assembly.
It is possible that some or all of the (4) 10 mm bolts are loose.
Your Acura dealer can fix this any time you are there for anything else. It takes an Acura tech about 2 minute to drop the overhead console and tighten the bolts. They do this alot-as the Hands Free Link (HFL) on 3Gs go bad all the time. The HFL is mounted in the roof console housing (interior colored part).
If you want to try it yourself-TSB 08-057 "Hands Free Link Doesn't Work" can be found in the 3G Garage (or by Google Search). The TSB has illustrated instructions for how to drop the console. The quick and dirty:
1. Remove moonroof switch (clips in place front and rear). Remove 7-pin moonroof connector.
2. Reach into hole where moonroof switch was located, and pull our map light assembly (clip in front tab in rear).
3. Pull down map assembly and look for the (4) silver colored bolts. Tighten bolts (seat + 1/4 turn more). Do not overtighted as they may strip.
4. Reinstall.
Old Oct 21, 2010 | 07:10 PM
mynewtls's Avatar
4. Reinstall.
Thank you!!! Took it apart and found that it had a broken clip on it and the bolts were not real tight. I carried to Acura and they replaced it under warranty.
Old May 14, 2016 | 12:15 PM
Preout's Avatar
4. Reinstall.
First of all thanks for this post. We were able to fix my sons sagging console in about 10 minutes. I am adding a little more info to step 2. If you pull down on the console a little bit you will see a clip or tab above each light assembly (part of light farthest away from the windshield). You will need to push in on both tabs to release the console. We got the left one pushed in with a small screw driver and the console dropped a little on the left side and then pushed in on the right one and the console dropped out.
Again thanks for this FYI/DIY
mlody
Dec 4, 2019 02:11 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
Skirmich
Oct 1, 2015 12:59 PM
hashbrown
Sep 29, 2015 12:13 PM
