over 50 MPH Vibrations
Old Feb 26, 2007 | 02:58 PM
the.bet's Avatar
My 04' TL is ratteling like you would not beileve. I pulled over because I thought I had a flat tire. I did not.
Some things to take into consideration, I did drive in some very deep snow yesterday and I have recently installed new tires.
The tires have not made any additional noise untill yesterday so I do not think that is the cause.
Could I have damageeed somthing driving trough 15 inches of snow?
If so where should I start looking?
Old Feb 26, 2007 | 03:00 PM
Eoanou's Avatar
'10 Hyundai Genesis Coupe
There's ice on your tires.
Old Feb 26, 2007 | 03:02 PM
Eoanou's Avatar
OR just like a batch of snow caught between the treads best idea is to have your rear tires on dry road and your front tires on a slippery road, snow or water, something slick. Lift the parking break put it into drive and floor it and give it gas in moderate amounts to keep it bouncing from 4~6K rpms, it should cause the tires to smoke and melt whatever is on off. Or you can drive it off tires should build up heat slowly.
Old Feb 26, 2007 | 03:28 PM
the.bet's Avatar
Ill give that a try after work
I did knock away as much ice as I could when I pulled over but it didnt seem to help
Hopefully thats all it is
Old Feb 27, 2007 | 05:09 PM
csmeance's Avatar
ust to ask the obivious, did you get the tires balanced properly on a hunter roadforce PRO machine???
Old Feb 27, 2007 | 08:50 PM
Yzerguy's Avatar
And if you have had them properly balanced (per csmeance) check to make sure you haven't lost any counter weights, it's very rare but I've seen it happen twice this winter on similar rims (in Calgary), apparently from road salt followed by freeze/thaw. Could be an easy fix before you go smokin your tires (what's the temp where you're at anyhow?). I can't answer my bumper colour issues, but hopefully this helps.
Old Feb 28, 2007 | 12:55 AM
the.bet's Avatar
The noise went away due to a nice thaw.
We had a helluva lot of snow this past week. Smoe towns got 29.5 inches in 1 day.
I recently bought blizack snow tires at "Discount Tire Company" so I assumed that they balanced them when the installed the tires.
I can't bieleve it was ice all along. Well that was easy.
Thanks for taking the time to post guys.
Old Feb 28, 2007 | 05:43 PM
bmaczo6's Avatar
It could have been snow or ice on the inside of the wheel around the brakes. When you drove through deep snow there is a possibility a chuck of it got lodged there.
Old Mar 1, 2007 | 06:19 PM
Eoanou's Avatar
It happens often when it snows, and many people confuse it for a flat tire or something else.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
