Outside Temperature Reading -
Old Jul 11, 2007 | 12:08 PM
clttr2002's Avatar
Has anyone experienced a problem with the temperature reading being way off - like 10-20 degrees? I have an 07 TL Type S and have noticed that the reading has been off since its warmed up outside.
Old Jul 11, 2007 | 03:03 PM
6spMike's Avatar
Mike's Silver Bullet
It might be normal; there's a thread here somewhere that describes the algorithm the car uses for the display, since the sensor in front of the radiator will pick up engine heat if the car has been sitting.
If it is still off after 5-10 miles at cruising speed, then there could be something wrong...
Old Jul 11, 2007 | 06:11 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
This is true there is a service news bulletin on it, some vehicles they can be adjusted through the MID by several degrees not sure about the tl though.
Old Jul 11, 2007 | 06:40 PM
clttr2002's Avatar
I read something about the conditions for the reading to update... but my problem is even after driving at freeway speeds. I guess I'll have to add that to the list...
Old Jul 11, 2007 | 10:49 PM
6spMike's Avatar
You can adjust it a few degrees:
https://acurazine.com/forums/ramblings-12/i-just-got-transformers-67481/
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
