Outside Temperature Reading -
Has anyone experienced a problem with the temperature reading being way off - like 10-20 degrees? I have an 07 TL Type S and have noticed that the reading has been off since its warmed up outside.
Mike's Silver Bullet
It might be normal; there's a thread here somewhere that describes the algorithm the car uses for the display, since the sensor in front of the radiator will pick up engine heat if the car has been sitting.
If it is still off after 5-10 miles at cruising speed, then there could be something wrong...
06 TL 6spd. Navi/A-spec
I read something about the conditions for the reading to update... but my problem is even after driving at freeway speeds. I guess I'll have to add that to the list...
You can adjust it a few degrees:
https://acurazine.com/forums/ramblings-12/i-just-got-transformers-67481/
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
