Outside temperature display
Old Dec 6, 2016 | 11:40 PM
stevenator56's Avatar
4th Gear
My 2006 TL usually shows the outside temperature about 4-5 degrees warmer than it actual is. Is this a common issue? If not, how do I fix it? I assume there is a sending unit somewhere?
Old Dec 7, 2016 | 12:01 AM
eastcoastguy's Avatar
What are you using to know the "actual" temp?
Old Dec 7, 2016 | 06:42 AM
vpasla1's Avatar
I think you can go +/- 3 degrees. I don't remember the exact procedure but it's in the forum for sure. So definitely do a search. I just remember you have to use the reset button while on the temperature display.
Old Dec 7, 2016 | 08:03 AM
https://acurazine.com/forums/third-g...egrees-540992/
Old Dec 7, 2016 | 09:47 AM
Oh Sickest TL's Avatar
Jeff
u must convert it to kelvin first and only can you switch it to fahrenheit
Old Dec 9, 2016 | 01:48 AM
YeuEmMaiMai's Avatar
OK here is how you test the sensor
1 clean it off
2 turn car ON
3 stick it in a cup of ice and water
should read 32F if not adjust it until it does. you can do + or - 3 degrees F, outside of that, take it to Acura dealer
Old Dec 9, 2016 | 07:11 PM
JDM96specCTR's Avatar
i dont even know how its accurate at all when its located on the radiator support only a couple of inches from the 200 degree radiator
Old Dec 10, 2016 | 12:31 AM
b15's Avatar
b15
This is why I relocated mine to right behind the lower front grill. Set the offset to 0* and it's been spot on ever since.
Old Feb 12, 2017 | 11:27 AM
paflyboy55's Avatar
8th Gear
My 03 MDX outside temp always shows -40 never changes. Could it be the sensor?
Old Feb 16, 2017 | 07:26 AM
^yes or it would be wiring issue
