Outside temperature display
4th Gear
My 2006 TL usually shows the outside temperature about 4-5 degrees warmer than it actual is. Is this a common issue? If not, how do I fix it? I assume there is a sending unit somewhere?
I think you can go +/- 3 degrees. I don't remember the exact procedure but it's in the forum for sure. So definitely do a search. I just remember you have to use the reset button while on the temperature display.
OK here is how you test the sensor
1 clean it off
2 turn car ON
3 stick it in a cup of ice and water
should read 32F if not adjust it until it does. you can do + or - 3 degrees F, outside of that, take it to Acura dealer
1 clean it off
2 turn car ON
^yes or it would be wiring issue
