Open door alarm
Open door alarm
My right rear door open door alarm won't turn off with the door closed. Anyone have this issue before? is there a fuse i can check, if so where and which one? could it be a bad door sensor?
Thanks.
Thanks.
Stay Out Of the Left Lane
Received 1,237 Likes
Very likely the door sensor. This May help - https://acurazine.com/forums/problem...-*pic*-876182/
I was looking at that thread, but my switch/sensor is connected. I can push it in and feel it. I guess it could be faulty..?
I was messing around with it and noticed that the rubber garment is missing on that door(attached pic). It looked like it was moved more towards one side so I moved it the other side and closed the door and the open door alarm was gone. I stuck a piece of paper in there seem to help. My car alarm has been going off every now and then, could this be connected?
could it be this some how be open door alarm be turned off/disconnected until i find a fix?
Based on the diagnostics you did I would say yes. Again remember we are talking about a simple electrical connection in a circuit. So even a small amount of movement may be the difference between setting off the alarm or not. And I'm assuming you mean grommet, not garment. Auto-correct can be a PITA.
Based on the diagnostics you did I would say yes. Again remember we are talking about a simple electrical connection in a circuit. So even a small amount of movement may be the difference between setting off the alarm or not. And I'm assuming you mean grommet, not garment. Auto-correct can be a PITA. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
haha yes grommet.
Does anyone know the part number for the door sensor and the rubber grommet? i can't locate it on any Acura parts online.
Check out this thread too and post #7 - https://acurazine.com/forums/problem...riving-797540/
Check the door striker. I just had this problem on my driver side front door, and the striker was loose. I just had to pop the cover off and tighten the two screws and I'm back in business.
DigiDrew818
1G TSX Problems & Fixes
20
09-18-2019 04:04 AM
Sohaib92
ILX Performance Parts & Modifications
12-30-2015 09:19 PM
