omg...need help asap
Old Nov 27, 2009 | 02:36 PM
libert69's Avatar
18psi
i was putting new weather stripping on the door and i needed to remove the bolt from the latch that goes from the door to the car. it had to be adjusted a few times to get the door to sit right. finally i got it right and the bolt snapped. how the hell do i get this thing out?
Old Nov 27, 2009 | 02:54 PM
DimwitRj's Avatar
that ONE RED tl
Get a bolt extractor, something like this.
http://www.sears.com/shc/s/p_10153_1...bolt+extractor
You're going to have to drill a small hole in the broken bolt and then ease it out with the extractor tool through that hole.
Old Nov 27, 2009 | 03:14 PM
libert69's Avatar
18psi
thanks. ill give that a try.
i had to remove this whole piece just to shut the door. the door opens and closes fine but just swings back and forth.
when i was playing around in that area, the long part that bolts to the car got pushed in and now it feels like its stuck there. im trying to get it to the longest position so i can reattach it but it wont budge. does this piece look broken?
hard to tell from the pics
Old Nov 30, 2009 | 12:05 AM
libert69's Avatar
18psi
ok so i bought a black an decker bolt extractor set. i followed the directions, center punched a hole, drilled with the right size bit, then started turning the extractor counter-clockwise. the bolt started to turn a little and then the extractor broke off. what the hell do i do now?
Old Nov 30, 2009 | 03:49 AM
YeuEmMaiMai's Avatar
take the extractor back and get a craftsman
Old Nov 30, 2009 | 01:54 PM
05BlkTL's Avatar
Drill the extractor out and get a better one like a craftsman. Are you sure you used the correct size? You can drill the extractor out then drill the whole bolt out. You need to know what the minor diameter of the hole so you don't fuck the threads. Or drill the whole bolt out including the hole threads and just retap and use a new bolt to match. Good luck
Old Nov 30, 2009 | 02:05 PM
05BlkTL's Avatar
Damn 5 min rule. Don't worry about this part, I meant the minor dia. of the bolt but that's just not needed. You can drill the bolt out (go smaller with the bit if your not sure) then follow that with the correct tap and chase the threads. Make sure they are clean and OK.
Old Nov 30, 2009 | 04:51 PM
libert69's Avatar
18psi
i think i could have gone one size bigger on the extractor. i have to buy a better drill bit now. whats a good type of drill bit to drill into a bolt?
Old Nov 30, 2009 | 08:22 PM
hardened carbon steel bits. titanium will weaken significantly under the heat load
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
Skirmich
Sep 15, 2015 06:41 PM
Billu99tl
Sep 13, 2015 11:30 AM
