'O7 TL engine replacement ?'s
Old Mar 26, 2014 | 09:42 PM
Jharris79's Avatar
Hi Acura community I'm a newbie and this my first post. Bought an 2007 tl 3.2 about 6 months ago with 82k on it, was driving around town the other day and heard a loud pop and the engine started running rough, then cut off. After I coasted into the nearest parking lot and got the car towed home I got to look at the damage. A hole in the side of the block and oil everywhere, so I'm guessing it dropped a rod. To the point of the post, I bought a used engine with 50K for a replacement. After looking at the service manual it says to remove the engine from under the car and dropping the subframe and tranny. I'm trying to do this myself at home without a lift. Is there any feasible way to this replacement from the top of the engine compartment or am I looking at expensive shop time? This would be my biggest job by far, but have done timing belt changes and so on, so average experience. Sorry if i wrote a book just trying to be detailed. Any help appreciated.
Old Mar 27, 2014 | 07:20 AM
Turbonut's Avatar
Sorry, can’t give an answer on pulling out the top, never did the TL, but have done a few FWD vehicles years ago without a lift. I actually dropped everything as a unit, wheel to wheel. Raise the car and remove all necessary components, top and bottom, even the shocks, steering, exhaust, use a 2x6 across the width of the assembly, remove subframe bolts, lower the jack, then use another to raise the body, or a couple on the sides at the sill. Not fun, takes time, but at least it's possible without a lift.
Old Mar 27, 2014 | 08:23 AM
more interested in how the bad engine died.
Old Mar 27, 2014 | 06:50 PM
csmeance's Avatar
sounds like a bent rod finally let go and put a hole in the side of the block after getting hydrolocked or something of the sort.
OP, good luck doing this since it will be a challenge. Drop it from below and raise the body of the car away from the engine/drive-train.
Old Mar 28, 2014 | 07:23 AM
I want to know the How part.
Old Mar 28, 2014 | 11:06 AM
YeuEmMaiMai's Avatar
remove hood and take engine out from the top of the car using an engine hoist?
Old Mar 31, 2014 | 10:10 PM
Jharris79's Avatar
Not quite sure How to raise a car 3 or 4 feet to clear an engine without a lift?
Old Mar 31, 2014 | 11:00 PM
JJH's Avatar
JJH
Rent a cherry pick
Old Apr 1, 2014 | 07:54 AM
515kbpUA7's Avatar
08 CBP TL-S
drop the engine and trans together with the sub frame from below. gonna be the easiest way
Old Apr 6, 2014 | 10:37 AM
ak20eg's Avatar
drop the whole subframe complete with motor and all... make sure to take out the lower transmission mounts while it is still in the car... and the torque converter/flex plate bolts while it is still in the car... mission if you forget them. also have to drop the steering rack with it as well. its a struggle with no lift but its easy enough. good luck
Old Nov 3, 2014 | 12:31 PM
corrado85's Avatar
Alien from Mars
best to search for DIY Auto Garage and rent a bay equipped with a lift and tools provided which in my area costs around $25/hr ~
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
wusty23jd
Sep 24, 2015 11:41 AM
iCrap
Sep 11, 2015 06:21 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
