'O5 TL Brake Light & VSA, HELP..
Old Oct 20, 2015 | 12:32 AM
MannyUA6_'s Avatar
5th Gear
Exclamation 'O5 TL Brake Light & VSA, HELP..
wassup everyone,
i been having this issue for a while now i was driving one night and had to step on the brake cause of some idiot, i noticed the Brake light come on on the dash, i pressed the brake down a little and it disappeared, few days later i notice it come on again and then eventually the VSA they are currently both on. i took it to two mechanics one says i need a Traction control system claims mines is broken i think that's bs, and the other believes its a sensor. what do you guys think ? any suggestions?
Attached Thumbnails 'O5 TL Brake Light & VSA, HELP..-20150824_084416_001.jpg
Old Oct 22, 2015 | 08:18 AM
flyromeo3's Avatar
You have to get the codes read using an ABS scan tool. It could be an ABS sensor or even a wheel bearing.
Advanced auto/ autozone....should be able to lend you the tool.
Report back what code is given to you.
We can then try to further assist.
Also, have you checked your brake fluid res.? Just double check youre not low.
Karanx7
Jan 28, 2016 02:01 AM
jmzb1002
Dec 7, 2015 03:50 PM
Tedward
Nov 3, 2015 10:22 PM
loweredCL
Oct 15, 2015 02:26 PM
m_rgaan
Oct 14, 2015 02:01 AM
