Not sure what happened when bleeding brakes..help needed please
Ok guys, I looked at a couple threads on how to bleed the brakes and did exactly what it said. So, I changed out my brake master cylinder. So then I knew I had to bleed all four corners. I had my girlfriend help me. I started with the front driver side, then front passenger side, then passenger rear, and last driver rear. At every corner, my girl pumped the pedal about 7 times and held it until I loosened the nipple. The brake pedal got hard every time. So I did the whole procedure and then started the car to realize that the brake pedal goes all the way to the floor. I tried it a couple times and it just goes to the floor. So my question is, did I do something wrong? Is the car supposed to be on while bleeding the brakes? Can someone please give me some advise
I made sure the brake reservoir was full at all times. Before bleeding the brakes, I bled the clutch system because I put a new clutch cylinder and slave cylinder and it came out great. My car is a 6 speed
Now you got me thinking, maybe I did the inside first then outside. If so, would that explain it?. The reason I ask for the cap is because for the clutch bleed, the cap has to be completely closed when you top it of and before the helper releases the clutch pedal
^+1 i was gonna mention that theres a bleeder in the back of the brembos, a lot of ppl miss that one.
and you're tightening the valve BEFORE letting go of the brake pedal right?
Bench bleed the MC before installation? If not, with the MC on the car, the MC needs to be level before bleeding and if the MC is not bled first, there will be a lot of pumping to hopefully remove all the air.
To make this a simple one person operation, do the following. Get a clear container, such as a juice bottle. Put a little fresh fluid in the bottom of the bottle and punch a hole in the cap big enough to slide your bleeder tubing through. Place the tubing in the fluid and the other end on the bleeder fitting. Now crack the bleeder and pump the brakes. The fluid in the bottle will act as a valve and prevent air from entering the system. I can do my entire care by myself in about 15 minutes (6mt).
For visual reference: (might want to leave the sound off)
No, I did not bench bleed it. What exactly do you mean by needs to be level?
How to bleed brakes using the " One person " method - YouTube
You got fluid with no bubbles at each nipple?
the youtube video showed on top is called gravity bleeding. i think its a better way since it doesnt require pushing the brake pedal to the floor multiple times. I do it, but it does take awhile, I let it go for like an hour for a flush and top off every couple min
Sometimes you can never get the air out without bench bleeding.
To the OP, in a pinch I've "bench bled" the brakes on the car. It's not recommended but it can be done. With one brake line disconnected, I used my thumb as a one way valve over the port and had a friend pump the pedal slowly. The fluid pressure easily overcomes your thumb pressure but the thumb prevents air from getting back into the system. This is not the right way to do this but you can try it in a pinch.
I replaced it because the sensor on it went bad. Yes I got fluid no bubbles at each nipple but it didn't come out with a force like it should. It kinda just creeped out
Agreed!
You mean the brake fluid level sensor? What were the indications/symptoms you had before replacing the MC?
If that's the sensor that is built on the mc, then yes the brake fluid sensor. The abs and vsa lights were on. If I unplugged it, the lights went away. So that is why I changed the mc
I'm pretty sure you gotta bleed the MC before installing it and bleeding the lines. I remember reading that if you run the MC dry while bleeding the lines, you have to pull it out, bench bleed it, and then do the lines again. I would imagine that installing a dry one wouldn't work either.
Ok, so I went to auto zone and bought the self brake bleed kit for $35. It's pretty nice and worked good. So I went at it again and bled the car 3 times again. Everything worked ut great and I got my brakes back but to me it seems like the pedal still travels down lower than it should. I compared it to my girls TL and hers doesn't go down as much as mine does before it starts braking. But my brakes def work and stop. I'm gonna drive the car around for a couple of days and see if anything changes. I really don't wanna take out the mc again and bench bleed but if that's what it takes then I will. But when I was bleeding the brakes , the fluid was going down in the reservoir . So thank you all for your help and I will let you know how it turns out
When at stop, hold pressure on the brake pedal to see if it drops, indicating air in the lines. I've bled MC's after they've been on the car by holding pressure on the pedal, slightly loosening the brake line, then tighten and do again. Extra work, but will correct the problem.
A bad booster would not give a soft pedal. It would give a hard pedal. You can still stop the car but you will probably be using two feet to do it. There's usually a hissing noise when you hit the brakes. It's kind of a bad combo, you hit the brakes but the booster is not helping. On top of that you create a huge vacuum leak when you hit the brakes which causes the engine to slightly rev up making it even harder to stop the car.
mada51589
Jan 9, 2025 04:40 PM
jamestheunderdog
Jul 19, 2016 07:58 PM
