noise during throttle
Old May 16, 2009 | 08:28 PM
bigshot82's Avatar
coming from the right front (wheel bearing maybe?) sounds kinda like some balls hitting each other; lasts only a second, when I throttle from stop or at low speeds. any idea?
Old May 16, 2009 | 11:22 PM
detailinguy99's Avatar
I have been having the exact same problem. Only cold and only giving gas. Weird.
Old May 17, 2009 | 06:36 AM
RonJonTL757's Avatar
Former Whyner
check your lugs its a start
Old May 17, 2009 | 11:00 AM
01tl4tl's Avatar
do the CV bearing test
With the car stopped- roll down the front wondows so you can hear better
Crank the wheel all the way right and hold it there- now slowwwly begin to roll forward in gear-- listening for a click click click noise- can only hear at very low speed
Now try it with the wheels all the way left- any click click click?
thats cv bearing failiure- common if you lower the car, hit a lot of potholes or the rubber boot breaks and the grease gets out and dirt gets in= failed cv joint
replace the entire axle assembly with 2 new cvs and boots with the axle shaft together.
Its cheaper than trying to fix one bearing and have the other fail a month from now
Torn boots are a major cause of cv failure- check them first- if torn you have found the problem
Old May 17, 2009 | 12:58 PM
bigshot82's Avatar
CVs are good; it's a different kinda noise (only on initial throttle, straight or turning)
Old May 17, 2009 | 02:07 PM
dwchow's Avatar
3rd Gear
Yes I'm having the same issue... is it like a hissing noise only on a cold start? I've had my CV axles and bearings checked as well and they look perfect.
Old May 21, 2009 | 06:30 PM
jdubub's Avatar
im having the same damn problem..... everytime i take it to my mechanic or i try to pinpoint it it wont do it!? go figure! lol but im ready for it to stop!
Old May 21, 2009 | 07:51 PM
Mine sounds like a broken bearing not in the engine but more in the exhaust area or transmission.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
