No Vtec???
Old Feb 21, 2009 | 12:30 PM
tkachuk's Avatar
No Vtec???
I just took my car to the dealer for the timing belt and water pump, and now i don't have vtec, no more vtec from 4900 rpm. What do you cause that ???? btw my car is 100% stock
Old Feb 21, 2009 | 12:35 PM
NAiL05's Avatar
Hows your oil level? There are several parameters the engine has to follow before vtec can engage. Is everything hooked up? Either way bring it back to the dealer and tell them to diagnose it. They did the job and it worked assumingly before you brang it to them.
Old Feb 21, 2009 | 12:46 PM
tkachuk's Avatar
my level of oil is perfect, i just change my oil 1 week ago, the vtec does'nt angage in any situation, i will bring back monday, but i want to know if is their fault before, because i don't want to pay for nothing
Old Feb 21, 2009 | 02:24 PM
csmeance's Avatar
how are you checking that it isn't engaging? Is your car fully warmed up?
Old Feb 21, 2009 | 02:39 PM
tkachuk's Avatar
yes my car is warmed up, i check it when i floor the car in 2 gear 3000 to 7000rpm, i do that in all gears and nothing.... you suppose to ear a different sound after 4900 rpm....
Old Feb 21, 2009 | 02:46 PM
csmeance's Avatar
in the TL the crossover isn't very noticeable... if you think its not engaging, take it back to them and tell them to check the work.
Old Feb 21, 2009 | 02:50 PM
tkachuk's Avatar
i know that the crossover isn't noticeable but when you have a cold air you usualy ear much more, monday i will take it back to the dealer ...
Old Feb 21, 2009 | 03:04 PM
JwongTLS's Avatar
Get a intake and hit vtec....if u still dont hear/feel it, something is definately wrong...Im assuming u have a base TL, Im not sure how hard vtec kick in a base model..maybe its time for a Type-S! Good luck with your problem
Old Feb 21, 2009 | 03:09 PM
tkachuk's Avatar
i got an manuel 6 speed with an intake, and defenitively don't ear nothing, same sound from 2k rpm from 7krpm
Old Feb 21, 2009 | 03:14 PM
JwongTLS's Avatar
Thats very unusual, never heard of anything like that..I would bring it straight back to the dealer asap and have them check it out.. I'd be hella mad if that happened to me..but at least u can still drive the car.
Old Feb 21, 2009 | 03:16 PM
JwongTLS's Avatar
Did u jump any cell? How about tryin to reset the ecu...Just a thought
Old Feb 21, 2009 | 09:42 PM
Bearcat94's Avatar
AZ Community Team
But you were able to tell before the Timing Belt & Water Pump right?
Old Feb 21, 2009 | 10:08 PM
csmeance's Avatar
take of the vtec solinoid and check to see that it's not binding. Also check for 15 - 30 ohms of resistance to make sure its getting the right signal.
Old Feb 22, 2009 | 06:25 AM
tkachuk's Avatar
yeah i was able to tell that i have a vtec before, the sounds of the engine is different you know right away that you miss something
Old Feb 22, 2009 | 06:27 AM
tkachuk's Avatar
i don't know where is the vtec solinoid, but i will reset the ecu this is the only thing that i can do myself
Old Feb 22, 2009 | 11:35 AM
01tl4tl's Avatar
STOP!!!!!!!!!!!!!!!!!!!!!!!
dont reset anything!!!!!!!!!!!!!!!!!!
take it back in - they forgot to hook something back up--things happen
VTEC should be FELT when it engages as the valve timing and duration changes- (google or wiki vtec to see how it works) making the rushing air sound as it pulls more air-- in a tornadic action-- into the engine
Old Feb 22, 2009 | 12:20 PM
1fsthatch's Avatar
damn
Old Feb 22, 2009 | 01:29 PM
RACINGHART03's Avatar
The vtec wiring/components are back by the lower timing belt cover so it is possible something back there is unhappy.
Old Feb 22, 2009 | 09:38 PM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
I got this guy, I got my vtec right here.....wheres my vtec!!! F'n dealer forgot to connect my vtec!!!!
(play on the "wheres my NOS" from My New Honda if you haven't seen it go youtube it lol)
Anyways to the OP I would take it back and tell them to fix it.
Old Feb 23, 2009 | 08:07 AM
tkachuk's Avatar
the dealer say that the timing belt lost one dent
Old Feb 23, 2009 | 08:19 AM
RC51Ryder's Avatar
Vroooom!!!
What does that mean?
Old Feb 23, 2009 | 10:06 AM
Originally Posted by rc51ryder
what does that mean?
x2?!?!?
Old Feb 23, 2009 | 11:33 AM
ssmtl2nv's Avatar
2009 g37s 6mt
Originally Posted by racinghart03
x2?!?!?
+3
Old Feb 23, 2009 | 01:50 PM
TL|GTX's Avatar
A Black TL
When i test drove the TL-S and 08 Base, they both felt and sounded the same. And how are your guys saying they forgot the plug something in, isnt vtec something built in the motor, the engages on its own when over the certain rpm?
Old Feb 23, 2009 | 02:04 PM
tc_terencec's Avatar
I MAKE NO SENSE
hm.... what IS VTEC supposed to really sound like? I mean... I just kind of always assumed that it always worked when rev = >4000
Old Feb 23, 2009 | 02:26 PM
NAiL05's Avatar
I dont think vtec should be that noticeable on a v6 motor. I get on mine a few times and it just has a slightly throatier tone but nothing that will slam you back in the seat. My H22 Accord on the other hand is a different story. You can feel and definitely hear when vtec engages. I dunno either way VTEC is an on/off system excluding ivtec and the hybrids. Still if you arent satisfied with the job bring it back to the dealer.
I also assume that you are saying there was a tooth missing on the belt.
Old Feb 23, 2009 | 05:11 PM
bhelsdon's Avatar
Usually problems with the Vtec will result in a check engine light.
Old Feb 26, 2009 | 11:20 PM
DasTeknoViking's Avatar
VTEC spool valve is right on the bottom of the engine above the oil filter housing. The harness MUST have gotten HACKED by the tech who hacked in the timing belt into your car.
DEMAND to see the belt with a tooth missing. In my 8 years with Acura, and hundred of timing belts behind me.... I have NEVER seen a bad belt. I'll even go as far as saying I never seen one break on a J series motor.
Old Jul 13, 2011 | 10:32 PM
EagleEye's Avatar
I am having the same problem. After a timing belt job. OP did you ever get it fixed?
Old Jul 14, 2011 | 08:34 AM
coykiam's Avatar
I just had a timing belt/engine work done by the stealership a month ago and around 1300 miles ago, currently at 51,xxx miles. The car moves pretty well but I don't feel like how it used to. Maybe its just me? But how exactly will you know VTEC is supposed to be engaging???
Old Jul 14, 2011 | 08:44 AM
coykiam's Avatar
just saw this thread after my reply, maybe this can help someone.
https://acurazine.com/forums/3g-tl-problems-fixes-114/vtec-not-engaging-826036/
But as someone not as mechanically capable as some of you guys here, Will you really feel VTEC? I mean I know for the TL it's not as dramatic as other HONDA's 4cyl line. I understand you can hear the engine and feel the car pull and pull.
Old Jul 14, 2011 | 12:34 PM
EagleEye's Avatar
https://acurazine.com/forums/showthread.php?t=826036
It's just a different sound to the engine. Normally it has a higher pitch and smooth wind sound when you floor it. But, when it hits VTEC, you'll hear more of a deeper bass sound... Best way I can describe it is that the engine is growling instead of hissing. And the acceleration when you punch it is different- harder and throws you back on your seat a bit even when you're at 60mph. I would be up to 80 in about a sec and a half (if that).
Old Jul 14, 2011 | 12:35 PM
EagleEye's Avatar
BTW-that's my thread :-) I am having an issue with the VTEC. Looking to find sometime this weekend to figure it all out.
Old Aug 22, 2011 | 03:13 PM
EagleEye's Avatar
Resolution? - VTEC is working fine. The roar is just not as loud anymore cause of new timing belt and new sparks.
If VTEC isn't working then you would get a CEL light.
IBankMouse
Jun 13, 2020 12:53 PM
Dunnik
Sep 15, 2015 11:52 PM
Tsov Tom
Sep 6, 2015 07:56 AM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
