Nut on Ichiba wheel spacer stripped
Old Aug 18, 2011 | 07:56 PM
iheartintegras's Avatar
I called the company to find out the exact size socket needed, the girl barely spoke english and eventually told me 11/16. I've been using a 17mm which seemed to fit snug. The 11/16 was definitely loose so I stuck with the 17mm.
Now I have this problem... any ideas?
Old Aug 19, 2011 | 09:04 AM
LoveMyTL-S's Avatar
Anyone?
Old Aug 19, 2011 | 09:42 AM
ez12a's Avatar
the overexplainer
worst case scenario:
buy a cheap socket that would just fit (on the too small side) and hammer it onto the nut, then wrench it off.
when hammering away mind your wheel bearing.
Old Aug 19, 2011 | 11:14 AM
rockstar143's Avatar
Dude...this happened to me...went to Sears and they have a set of sockets to remove stripped bolts...it worked on one of mine, but on the other side a few months later I put the spacer on with an impact wrench and it ended up tightening it to the point that even with the nut remover, it kept stripping...I'll end up cutting off the stud or try to carefully cut off the nut. But will require some patience.
Torque down to spec at 80 ft/lb. Don't push it. Needless to say, my spacers are now a part of my car...
Old Aug 19, 2011 | 11:36 AM
Turbonut's Avatar
Go for the small size you need in an impact socket.
Old Aug 19, 2011 | 12:50 PM
ez12a's Avatar
the overexplainer
just fyi also, not directed to the OP necessarily, but use 6 pt sockets when possible esp. working with cars.
Old Aug 19, 2011 | 12:51 PM
I picked up a set of Irwin stripped nut removers today, hopefully this works.
Old Aug 19, 2011 | 01:08 PM
Bearcat94's Avatar
AZ Community Team
I don't see where this would be so aweful.
Unless you an absolute wheel whore like bforbrian or cccolts.
Old Aug 19, 2011 | 02:33 PM
Not awful at all...I'm ok with it...it just forced me to finally figure out the fender rolling and camber and making it work. I'll deal with it if I ever need to remove them.
Old Aug 19, 2011 | 02:51 PM
Dino81's Avatar
Happened to me on 15mm spacers. The nuts are really shallow and not much to bite on. I have a stripped lug nut removal tool, and bc the nut was so shallow, this didn't work. Ended up air hammering, and angle grinding it off. Of course ruining the spacer in the meantime. Best of luck to u! Hope ur case turns out better than mine.
Old Aug 22, 2011 | 03:35 PM
CORUPT's Avatar
causing mischief & mayham
I ended up not using those thin bolts because I was afraid that would happen. I had enough room to use a regular open ended lug nut.
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
obert
Nov 14, 2015 09:59 PM
yvr_tsx
Sep 15, 2015 01:14 PM
jmoney2001
Sep 11, 2015 12:07 PM
