No reverse! Need help!
Old Dec 5, 2018 | 12:49 PM
Jacob Morales's Avatar
3rd Gear
I put my 2007 TL into reverse and it jumped. Now I have no reverse. The reverse lights come on but it just revs up like it would be in neutral. Drive works fine. Also the belt had come off before that and it wasn’t on when the reverse went out. I was just backing it down the driveway to work on it. Don’t know if that has anything to do with it
Old Dec 5, 2018 | 01:02 PM
Check your axles.. may have just snapped them
Old Dec 5, 2018 | 01:21 PM
peter6's Avatar
He wrote that drive works fine, which means axles must be fine. Guess we need transmission guy to solve that one.
Guess that's as much as I can help:
Except none of those seem like simple checks. Does any lights blink, does check engine light is on? Do you have enough ATF?
Old Dec 6, 2018 | 05:23 AM
3rd Gear
The check engine like is on but it has been on for some time due to a fuel system code. I did not get to run another check since the reverse problem. I also have enough ATF. Could it be related in anyway to my belt coming off?
Old Dec 6, 2018 | 05:57 AM
Midnight Mystery's Avatar
Null and proud of it
No!
Any other odd noises, harshness, anything else?
Old Dec 6, 2018 | 08:00 AM
Jackass's Avatar
Does the dash light show it is in "R"?
Old Dec 7, 2018 | 08:37 PM
3rd Gear
Fixed!
The bearings on one of the tensioner pulleys locked up and made the pulley come off then the belt. I replaced the belt and pulley now reverse works. Can’t figure out how it was related but an easy $50 fix so I’m not complaining. Thanks
Old Dec 7, 2018 | 09:15 PM
Can't ho wrong with that and thanls for the uodate!!! The best part is your tranny is fine!!!
TL Peak N
Oct 10, 2010 04:59 PM
t3hanarchist
Oct 29, 2009 12:47 AM
iloveTL
Aug 31, 2009 12:29 PM
triggerc
1G TL Performance Parts & Modifications
May 1, 2007 04:38 PM
FiftyFive
Aug 9, 2005 12:40 PM
