A few problems randomly pop up
Can someone please offer some insight in where I should start looking first. I had a few problems pop out of nowhere today.
I was on my commute home and all of a sudden, my temp display showed only three dashes, and the turning signals and high beams stopped working, With no display on the dash.
Got home and was about to google to see where I should look first but noticed my key fob not working along with the driver side power door locks. The on-dash display showed that it was not linked to the car anymore.
So I looked up the instruction here and tried to re-program it, with no success and it also drained my battery. I ended up having to get CAA to give me a boost.
Now here is the strange part in the midst of driving around to get charge the battery again. The signals, high beam, temp display, and lock started to work again. But for some reason or another, my rear windshield defroster did not for the first part of my drive.
I'll be picking up a new battery tomorrow, before trying to trying to reprogram the fob again. But can some point me in the right direction in where to look.
I sorry for the long-winded post but I just didn't want to leave anything out
If the battery was more than three years old and you have typical driving/maintenance habits, then I'd get the new battery and see if the problems go away.
If your battery was newish or you typically keep it topped up, the problem will likely return when your new battery is subject to whatever drained the first. There are lots of posts on parasitic draws on this site.
If your problem is a loose/corroded connection, your new battery will not help with your problems. There are also lots of posts on looses/corroded connections.
I'm hoping its just an old battery.
These random problems seem to have electricity in common. I would have guessed bad battery but a bad battery could also be a symptom (bad alternator, bad connection, high parasitic draw).
daoism76
Jul 16, 2012 12:30 AM
