No outside temp display
Old Jan 17, 2006 | 08:03 PM
2xselectrak's Avatar
On my guage pod the outside temp display just says OUTSIDE TEMP-----*c.
Everything else works. I had my car in at a stereo shop getting a sub put in but they just ran a (+) to the batt and tapped into the rear sub....has this happened to any others? let me know......where the temp sensor is?, fuse? ?????
Thank you
Old Jan 17, 2006 | 08:41 PM
avs007's Avatar
You have Navi? My coworker said he got a recall letter about this. (We both have 05's, but I didn't get such a letter).
It's related to the bluetooth and the loss of radio presets, and killing the battery issue. You experiencing a loss of radio presets?
Old Jan 17, 2006 | 08:47 PM
1995hoo's Avatar
Keep Right Except to Pass
My '04 flatlined twice on extraordinarily hot days last summer, but that's not too likely to happen at this time of year because it's supposed to flatline at temperatures above 113 F degrees. Try looking in the 3G TL garage forum, or in that other thread where someone collected all the TSBs. Your issue is addressed there.
Old Jan 18, 2006 | 03:48 AM
A_UFO's Avatar
Lightbulb
Check if this applies to your TL TSB 05-029: Product Update: DTC B1161 with O/S Air Temp --- or Intermittent Dead Btry
Old Jan 18, 2006 | 04:48 AM
SouthernBoy's Avatar
Registered Member
Either disconnect a batter cable for about 4 seconds or remove breaker number 7 for around the same amount of time (I think it's number 7.. you may need to verify this).
If you don't fix this and leave your car sitting for several days, you will have a dead battery. The ECU goes into an error loop and just eats up cycles when your display is flatlined.
This happened to me when my car was 6 weeks old and just 36 hours from leaving on vacation by car.
If you do a search on flatline, you'll probably turn up quite a bit of info.
Old Jan 18, 2006 | 09:39 PM
eimea's Avatar
9th Gear
This happened with my 05 TL and the dealership was aware of the problem and fixed it. Not sure exactly what it was, but it is now fixed. Take it in under warranty.
ITSJESTER
17
Dec 6, 2018 02:29 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Jboat
Sep 30, 2015 10:58 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
Froid
Sep 27, 2015 06:16 PM
