New trans with weird issue
Old Jan 31, 2019 | 08:49 PM
laid67's Avatar
Hey all,
I just picked up a 30k mile AV6 trans and installed it into my 04 TL. Install went pretty smoothly, trans seems to work great. But I have an intermittent issue where the trans will shift down into 4th, the blinking d light comes on along the check engine light and stability control light. I get P2770 and P0977. I swapped shift sonoid b from my old trans. And bench tested both. No change, I also bench tested the torque converter clutch Solonoid. No issues with that either.
When it acts up, I can shut the car off, clear the codes and drive another 50 miles perfectly fine.
Any ideas?
Old Jan 31, 2019 | 11:10 PM
ifeliciano's Avatar
ECU/Trans reset?
Old Feb 1, 2019 | 11:02 AM
https://acurazine.com/forums/3g-tl-p...-p0977-919601/
I take it you installed fresh DW-1 fluid after the swap too?
Old Feb 3, 2019 | 01:19 PM
laid67's Avatar
yup. Fresh DW1. I broke down and finally took it to a shop, they said it sounds like an electrical issue and the only thing he could do is test the harness one wire at a time. So I guess that’s my next course of action. My only concern is that an intermittent issue may not show it self when testing continuity through the harness.
also. How can I check if my PCM is up to date?
tarponman85
Nov 3, 2007 04:03 AM
JUBIE
Jan 8, 2006 11:38 PM
Southern
Oct 11, 2004 07:29 PM
KrZyTypeS
2G CL Transmission Recall Q & A
Jul 26, 2004 12:09 PM
