New ballast. Do I need to align headlight focus?
My ballast or igniter is bad so I will replace both. I will need to remove the headlight assembly. In one of the videos, for the installation of a brand new headlight assembly, they align the focus of the light after installation.
Is this last step necessary if I am only replacing the balast/igniter?
I'm sure you've probably already tried to determine; however, if you can 'easily' (kind of doubt it) get to / remove / install the new components without said removal you may get away without the adjustment?
