acura tl-s 03 headlight
Old Dec 16, 2005 | 12:01 PM
subzeros's Avatar
3rd Gear
Question acura tl-s 03 headlight
My Right Xenon lamp is not working. I replaced the bulb and thats not it, should i replace both the igniter and the ballast or there is a good chance its just the ballast. The biggest question, how do i get to the headlight? Should i remove the bumper to get to the headlight or is there an easier way? If i do have to remove the bumper are there any sensors that i need to be aware of? thank you in advance for any help
Old Dec 18, 2005 | 01:49 AM
Split_TL's Avatar
First you Have to take the bumper off to get to the headlight and the ballast etc..Its not really that hard there are many DIY on this forum, its mostly clips and a couple bolts. As for the Ballast (its actually called an inverter) i would first test it, by hooking it up to the other headlight, after that you should be able to determine its ifs the Ballast or Igniter. If it is the ballast you could order one online and its not that expensive. I got mine for 180 shipped brand new.
Old Dec 18, 2005 | 08:43 AM
subzeros's Avatar
3rd Gear
Smile
thanks a lot..i will do that today and find out if the ballast is infact the problem.
TLrascal
Aug 3, 2018 11:00 PM
theinsvnity
Sep 10, 2015 10:22 PM
Glorygang600
Sep 5, 2015 01:17 AM
voigt
Sep 2, 2015 10:44 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
