Need some help with LW battery install
Old Apr 9, 2014 | 09:51 PM
FamilyGuy's Avatar
Basically, I removed the OEM battery and all the plastic pieces around it.
New battery slips against the metal base too much for peace of mind, and I've got it tighten down as much as possible, any more and the plastic holder will break.
I'd like to use the braille bracket for this battery (B2317) and lay it down horizontally on the tray, that will hold it 100% as the bracket wraps around the battery and screws into the base, but then the problem is the negative cable wont reach, it's only ~4-5" long. I know I can buy a longer cable but don't know where to look or which one to get.
Any ideas / suggestions?
A friend of mine can relocate it to the trunk. Any issues with voltage drop through a longer cable (positive)? I assume this would need to run from the trunk back into the engine bay? Not sure I want to go this route, I like the thought of keeping the weight up front for traction.
Sry for the crap cell phone pic:
Old Apr 10, 2014 | 10:34 AM
1black_seven's Avatar
Slot Machine Lubricator
Swoosh would know about this.
But I would just relocate it to the trunk
Old Apr 10, 2014 | 12:35 PM
losiglow's Avatar
I've got mine sitting directly on the chassis beam with industrial double stick tape. Kind of ghetto, but it works, and without adding additional weight from mounts, panels, etc. It's been there two years this summer. Still works like a charm (through two Utah winters) and hasn't moved an inch.
Old Apr 10, 2014 | 03:50 PM
AccordFlex's Avatar
Relocating the battery to the trunk is definitely a pain in the ass, but totally worth it. Frees up so much room on the right side of the engine. More room for activities.
Old Apr 10, 2014 | 04:01 PM
Vlad_Type_S's Avatar
Registered Bike Offender
Old Apr 11, 2014 | 05:17 PM
FamilyGuy's Avatar
Thanks fellas.
Was just in walmart buying oil and saw they sell a bunch of negative cables at different lengths. Just measured and I think a 8-9" will do for it to lie flat. Peace of mind until I decide whether or not to relocate to trunk.
Old Apr 16, 2014 | 11:30 AM
brian6speed's Avatar
Lone Wolf
Braille sells mount kits for both vertical or horizontal positioning.
I installed mine on the side in the stock battery location. I thought about moving it by the back seat in a battery box, but I am happy with it for now.
Here is a link that shows the braille mounts.
http://www.braillebattery.com/index...._series/mounts
Old Apr 16, 2014 | 09:58 PM
FamilyGuy's Avatar
So purty nice
I have it laying down horizontally now with shorter j-hooks. I might do their bracket, but it's one expensive little bracket.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
TLDude876
Dec 28, 2016 03:18 PM
BoricuaTL
Apr 8, 2016 01:08 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
