Need help identifying noise from right front
I have a 2005 TL AT with approximately 167k miles (no mods) . For over 8 months I've noticed a sound coming from the right front side of the vehicle when I slowly accelerate from a stop. I cannot hear the higher pitched clanking sound when I accelerate fast, nor do hear the noise after roughly 15 mph. I can hear the sound when turning left and right and also going straight. It sounds like something metal is turning inside then dropping, but I could be wrong. I believe the noise is vehicle speed related, not RPM related. Any help would be greatly appreciated. I've added a link to the video I took.
Thanks!!
Thanks!!
That's a weird one, dunno.
Broken sway bar end link?
Is the passenger side motor mount shot?
Usually if the end links are gone, the noise is only audible when going over rough terrain when the LCA's are moving, but going on a flat surface although you say you know it's not a CV joint, I'd make a double check. When turning in a figure 8 and accelerating, no noise? Also check the intermediate bearing, but that will usually cause a vibration.
Hoonigan
Thanks!!
2005 Acura TL clanking sound - YouTube
Thanks!!
Engine mount is usually under all types of acceleration.
marcelft
07-10-2018 06:17 PM
