Need help with Check engine light.
Old Sep 30, 2015 | 11:41 AM
Gooner86's Avatar
I got the code P2631 and I switched the O2 sensor with a new one. When first installed the light went away, but after 20 or so minutes it came back on. What could cause this? Is it the sensor I bought is bad or something else. I have a 2004 Acura tl.
Old Sep 30, 2015 | 11:43 AM
which sensor did you change, there's 4. BANK 1 and 2 upper and lower.
Old Sep 30, 2015 | 11:56 AM
Gooner86's Avatar
It was bank 2 sensor 1
Old Sep 30, 2015 | 11:58 AM
so, you still get the same code after you changed sensors?
did you unplug negative battery cable for a minute or two, afterwards?
Old Sep 30, 2015 | 12:56 PM
Gooner86's Avatar
My buddy who is a mechanic changed it for me and he gets the same code. He has worked on my TL before so I trust he knows what he is doing
Old Sep 30, 2015 | 12:58 PM
flyromeo3's Avatar
Whats the brand o2 sensor that was used?
Was an OEM one used?
Old Sep 30, 2015 | 01:14 PM
Gooner86's Avatar
It was a denso sensor
Old Oct 1, 2015 | 07:07 AM
Turbonut's Avatar
Put the "used" suspected bad sensor into upper bank 1 position and see if a code follows. Think it should be P2628-Oxygen Sensor Pumping Current Trim Circuit High Bank 1 Sensor 1.
After replacement, if no code indicating bank 1 sensor 1, it's not a sensor problem, but if the above code follows the sensor, then it is a bad sensor.
Old Oct 1, 2015 | 07:30 AM
Has a mechanic friend that 'knows what he's doing'
comes on a forum to ask for help
AndrewS
19
Mar 14, 2024 06:59 PM
rklatzkin
Sep 23, 2015 04:08 PM
BigJilm
Sep 21, 2015 08:32 PM
MyBlackBeauty
Canada
Sep 14, 2015 05:28 PM
elietania
4G TL Problems & Fixes
Sep 5, 2015 06:52 AM
