Navigation and Menu Lights Are Out
Noticed my a couple of my navigation/menu lights are out in my 2005 Acura TL. I read a few posts on here and I believe they are individual lights only to be replaced by taking out the radio. However, I have no idea how to do that. Can anyone help or should I just take to a shop???
if you are not mechanically inclined; or have no experience with plastic panels- don't do it. there's a thread around here somewhere if you search, but you should have at least an idea of how to do it or you might snap them.
I have the same issue. I have lights out on the steering wheel, the driver's-side temp control buttons on the center console and one behind the fuel gauge. Searching this forum, I find post-after post about how easy it is, how hard it is, or that the answer is in the forum elsewhere. However, nowhere can I find the answer. Can anyone provide a link to detailed tear-down and install instructions for these lights, including the steering wheel? I have an '05 TL w/Navi.
hmm. i've got the exact same issue. and i noticed the same thing with my temperature and emergency lights -- indeterminate periods of time where they turn on and off. then a friend suggested that its not a bulb, or even a fuse, but simply mere loose wiring. i simply made a fist and smashed the plastic area right below the emergency light and all the lights went back on. (non-navi btw). won't hurt to try before taking it apart. gl! i hear its not the most difficult thing to do, but very tedious; and i thought that if i were to change the lights out, i might go for a white light instead of the mellow green
setup/info light out on nav console
Was at the dealer yesterday for a oil change, asked about replacing the light and to my surprise was told that the whole console/dash would have to be removed. at about $200 labor. Damm, Damm, Damm
Me too me too! Some of my center consoles lights blew out. Another thing that irks me is the shifter light. I mean I can see it on the dashboard and I know the feel of it but still... At night I would like my shifter to be lighted up.
Had the same issue. Here's my post from my adventure replacing them.
https://acurazine.com/forums/showpos...4&postcount=42
rockyboy
Aug 4, 2024 10:35 AM
rockyboy
Jan 25, 2016 06:00 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
