Navi not dimming when on auto
Old Jul 21, 2011 | 01:10 PM
wrxSTIcy's Avatar
Hey guys, kinda new to this forum, had an old account, sold my 04 TSX and bought an 05 STI, forgot my log in info. Just swooped an 06 TL with A spec upgrades but I notice that when my NAVI is on auto, it doesn't go to night mode when I turn on my headlights like my TSX did, I tried searching, no results
Old Jul 21, 2011 | 01:18 PM
csmeance's Avatar
it's a fairly simple fix, press the down arrow on your gauge cluster and your done!
What happens is that there is a MAX button on the gauge cluster, and when you press that it overrides the AUTO function on the navigation system. When you press down once, it goes down to FULL bars which is MAX in the day but slightly dimmer at night. This dimmer night setting allows the navi to switch into night mode.
Old Jul 21, 2011 | 02:08 PM
wrxSTIcy's Avatar
That is fucking awesome, thanks man! They didn't have the Max button on the TSX, I did press the max button last night, I'll try that later!
Old Jul 21, 2011 | 10:42 PM
paperboy42190's Avatar
also check that in the setup menu, the setting is on AUTO, not DAY or NIGHT
Old Jul 22, 2011 | 01:28 PM
wrxSTIcy's Avatar
Right on, It worked. Also, I noticed that when I put the car in reverse, the mirror automatically adjusted down so I can see the curb when I park, now it doesn't do that anymore after I played with the seat memory functions did I mess something up?
Old Jul 22, 2011 | 05:03 PM
NetGnome's Avatar
The mirror must be selected on the dash mirror switch. Put it in reverse and select the right mirror, wait, then left mirror to see them change. Sometimes the motors do get stuck.
Old Jul 22, 2011 | 06:52 PM
ez12a's Avatar
the overexplainer
^ditto
Cars do it differently, for Acuras the mirror that tilts down is the one the mirror switch is controlling. Selecting the right mirror on the mirror switch (as if you were to adjust it) would cause it to tilt when going into reverse. If the mirror switch is not selecting any mirror, then no mirrors will tilt.
BMW E46 on the other hand, will refuse to tilt the pass mirror if the switch is set to adjust the passenger mirror (presumably because it's waiting to be adjusted).
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
soupi
14
Nov 15, 2015 11:15 AM
malvothegreat
Sep 29, 2015 12:38 AM
