Nav and door sensor issues with '07 TL-S
5th Gear
Hello all,
New member here and after lurking for awhile decided to join and get some input. Had my '07 TL-S for a little more than a year and it's been great. Only issue I've had before is a pretty severe rattle in the back speakers which was replaced under warranty. It just figures that as my bumper to bumper warranty expires I start to have a little more complicated issues. So wondering if I could get some input and or advise.
Issue 1. I will be driving and either hit a small bump or make a turn and the doom lights come on and the car makes a "ding" noise as if there was a door open. Only on occasion will there be a door open message on the display cluster. Also, the car locks itself which seems bizarre because the car's in motion. After reading this section of the forum I'm thinking it may be a door lock/sensor actuator? Not sure if thats correct.
Issue 2. Every time I try to get to the main menu of the navigation screen I get this message. Now I'm not sure if I need to fiddle with the DVD drive in the truck (take the disc out and put it back in) or I just need to get the updated disk. I don't think anything is wrong with the nav system itself considering the rear view camera works just fine.
![](http://i29.photobucket.com/albums/c266/timboogeyman/photo.jpg)
Thanks in advance everyone.
as far as your first issue it sounds like your door strikers need to be adjusted. You can verify this by sitting in you car while its on and push against your door and see if you get that message of door open. You pop the plastic cover off and losen the screws a little and make sure they are all the way adjusted inward toward the inside of the vehicle. You didn't say which door it was...start with the door that is affecting the vehicle. The door locks locking while the cars is in motion....say one to two minutes after you get going...this should be a setting in the dash. I like it when it locks in D and unlocks in P.
Your last issue/message/pic I can't help with because at work, pix are blocked on this computer. Hope this is useful for ya! let me know how it works out
timboogeyman (08-19-2011)
KBPftmfw
Issue 2: If you look in the 3G garage and go to the TSBs you will find one for this read disc error. Check your disk. If you have gouges that go around the entire disk then your DVD drive is bad and will need repaired/replaced. I just had my drive and nav disc replaced last Saturday for this same read disc error.
5th Gear
And sorry to anyone who this was a repost for. I looked a little harded and found this post a couple months back.
https://acurazine.com/forums/3g-tl-problems-fixes-114/door-light-comes-while-driving-797540/
Thank you both! Seem to have been quick fixes! Glad I didn't call the dealer.
ahh the typical dvd drive failure message. i went through the same thing before. send your dvd unit back to alpine for a $158 repair for the dvd mechanism. this happens to a lot of honda/acura dvd drives btw, yours is no exception.
2012 abalone ave unit D
torrance, ca 90501
torrance, ca 90501
US Navy Seabees
torrance, ca 90501
torrance, ca 90501
KBPftmfw
Took the disc out and there werent any "gouges"per say (no chunks or clips on the disc) but there were small rings around the edge of the disc (not sure if thats similar to what you saw) but I just cleaned the disc off with a lens cloth and popped it back in, got to the main menu and ran an address...no issues. But maybe this could be the start of the drive going back. Was yours under warranty? How much does the dealer usually charge if you don't mind my asking?
My advice: if you are under warranty print out the TSB and schedule an appointment to take it in to your dealer. All they need to do is eject the disc, look for circular scratches and you will then be diagnosed as a faulty nav drive.
GOOD LUCK!
KBPftmfw
If you are under warranty, the disc is automatically replaced by the dealer. You will not get the most current version, but, they do upgrade you based on year of car and nav drive version. There is a TSB in the 3G garage that covers the disc read error inside and out.
5th Gear
torrance, ca 90501
torrance, ca 90501
cycdaniel
12-17-2019 10:58 AM
tman570
06-11-2019 07:56 AM
