My turn signal doesnt work!
Ok, this morning I wake up and found that my turn signal doesnt work!
At first i thought it was the bulb, but it was fine cause it turns on and all.
But when i try to signal, it doesnt signal at all..i dont even get the little arrows inside the guage to show that im signaling.
Im out of warranty and acura dealership wants to charge me 102 dollars just to DIAGNOISE the problem...and they will tell me whats wrong.
What kind of stupid service is that? Make people pay to see whats wrong and let them decide if they want to fix it or not..ur not getting me to pay that 102 dollar...cause im asking here! ha
Does anyone know anything about this? Did one of the transformer burn out or whatever?
06 TL 6spd. Navi/A-spec
Could be your turn signal combination switch? If both your turn signals dont function at all, try your hazards and see if they work. If they work its not a turn signal relay or a fuse.
ok then if the hazards dont work which is a seperate swith, its kinda hard to figure it out without the car, but you say the turn signals do lite up is that only the running lights? And when the switch is turned either way the turn signals on both sides including side markers dont work?
ok i would look at the drivers underdash fuse/relay box and try to find the hazard/turn signal relay and see if there is another relay of the same and swap them out
alright after looking at the ETM look at the underhood fuse box and find the turn signal fuse check to see if it is blown which im thinking it might be
do u know the exact location? under the hood or inside the car? which number is it?
i see sunroof, igop1, ighac..p/w rr l..and such but i dont see the signal one.
there's 33 number for the inside one..be helpful if u can tell me which number to check
I couldnt really well you i would look under the hood first at the fuse box i am looking at an 7th gen accord etm so im sure its not the same number fuse there should only be 1 fuse in the under hood fuse box check under the cover and it should be a diagram and find the turn signal fuse. If you cannot find i will go out to my car and look.
Mike's Silver Bullet
If it blows again soon, there's something else wrong.
It used to be that the bulbs had dual filaments, one for running lights, and one for turn signals. I don't know if our cars use those, though.
Aren't the rear signals LEDs? Are the fronts LEDs too? I'm going to check when I get a chance.
2005 TL (base) My turn signals work when the engine is off and the key turned, but not with the headlights off or with the engine running and headlights on...any ideas?? Any help would be greatly appreciated.!!!
JavierC24 (10-17-2021)
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
