My TL is going nuts
Old Aug 16, 2011 | 09:29 AM
06TLpearlywht's Avatar
Red face My TL is going nuts
Hey i live in New York and its been raining non stop for the past 3days and sunday night my oem keyless entry pager was not opening nor locking my doors and when i entered my car from using the key i couldnt lock or unlock it from my driver side but my passenger side could..When i turned my car on my horn went on once and my wipers wouldnt work if i flick it up for that 1 swipe but it would work when i flick it down and also my turn signals wouldnt work when i put it to turn left or right but would work when i put my hazards.. Never had any problems with my car other than my engine mounts.. I left it in my garage to maybe let it dry up ever since havent checked up on it yet.. Im not sure if i might of gotten something wet.. I also have a Aem v2 cold air intake not sure if it would have anything to do wit the problem..What do you guys think it could be?? Super nervous
Old Aug 16, 2011 | 09:34 AM
check fuse box. make sure there is no evidence of water in the fuse box.
there's a drainage tube that sometimes gets clogged. it will trap water and lead it to the fuse box.
Old Aug 16, 2011 | 09:44 AM
ok ill take a look at that later on today.. So this wouldnt have anything to do with the computer right?
Old Aug 16, 2011 | 11:58 AM
**WhItE-aNgEl**'s Avatar
Nope nothing wrong with your computer I had the same issue it wasnt my drain tube tho. I paid $500 to get the leak fixed that was coming from bottom left corner of the windshield and dropping on my fusebox i had the same symptoms as you too.It's been raining really hard here in nj too and no problems for me anymore. Good luck bro I hope you don't have the same issue I did, it's a PIA.
Old Aug 17, 2011 | 10:51 AM
hey i checked my car last night everything back to normal but should i still try to repair the leak if i find it?? it has never happened before not even at the car wash, it was just this heavy rain going on these past few days
Old Aug 17, 2011 | 11:20 AM
Yes find the leak ASAP! Everything is back to normal because your fuse box dried up. Trust me I went thru the same exact thing but prob 10x worst. And I wouldn't doubt your leak is coming from the same place as mine did. Call this number theyre a mobile unit so you have to take your car to a dealer so they can look at your car they don't have there own shop.
(732) 673-6344 ask for Scott.
cycdaniel
Dec 17, 2019 10:58 AM
02tljj
May 2, 2019 08:56 AM
lland
Oct 4, 2015 04:47 PM
Kitsune13
Sep 24, 2015 02:25 PM
NetGnome
Sep 7, 2015 08:33 PM
