Are my motor mounts bad? + Which oil do u use?
Hi All,
So I have done every single repair on this engine that can be done besides replace the torque converter or Transmission. I changed my Transmission mounts about 5 months ago, but the Front, Rear and Side motor mounts around 4 years ago I'd say (maybe even 5). In those 5 years, I have done a lot of maintenance, including adjusting valves, timing belt, etc. Eeven after all that work I still get vibrations in gear at idle (worse with the A/C on). I am thinking maybe the front and side mounts are worn out by being on an engine that was not running in optimal condition. I have a video here showing the front/side mount as well as the overall engine view as I hold the break and accelerate in drive and in reverse, as well as neutral. Can anyone tell me if I should replace the front and side mounts again? In reverse the engine seems to have a lot less play in my opinion.
Thank you all in advance! These 2 mounts are 300$ total so I dont wanna waste it but I think it'll help. The vibration is all I want gone. I want to not even be able tell if the engine is on.
Side Question: Amsoil Synthetic vs Penzzoil High Mileage Platinum vs Mobil-1 Extended Perfromance High Mileage Oil?
Also, I will just have my trusted mechanic do it. So Im sure he will neutralize them
