Is my motor mount broken?
Old Oct 24, 2011 | 10:52 PM
navarretg's Avatar
2004 Acura TL
Ok, im not sure this is my motor mount but I just want to be sure.
ok and heres the one in front of the fan, not a really good pic btw
Old Oct 25, 2011 | 03:31 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Thats the cover bro, but you wouldnt be able to see it from the outside, do you feel alot of thumps on speed bumps for any hard shift changes when changing to reverse ..???
Old Oct 25, 2011 | 04:49 PM
navarretg's Avatar
2004 Acura TL
I only feel a lot but not excessive vibration when I do a cold start. It only last about minute and a half or when the Rpms fall below 1k.
Old Oct 25, 2011 | 04:51 PM
vietxquangstah's Avatar
normal
Old Oct 25, 2011 | 05:16 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Yea man thats normal like vietx said, you will def feel and hear when you mount goes out..
Old Nov 5, 2011 | 05:48 PM
beboricua's Avatar
Finally i heard that vibration its normal. Was my worry for a log time. But anyway i do replace that motor mount because i heard a big bump when accelerate.
Old Nov 5, 2011 | 07:53 PM
ez12a's Avatar
the overexplainer
cover's an indicator it's probably worn and will need replacement if not now, soon.
If there's enough movement to crack the cover then you know something's up.
Old Nov 5, 2011 | 08:35 PM
gatoferoz25's Avatar
That happens to me I hit a big bump an then my motor mount cover started to crack little by little an I felt the same vibration after that I just decide to cut open the cover of the motor mount an i saw big damage on it
Replacement was really easy it only took me like 10 min not even but good luck with yours bro
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
