My Mirrors
Old Sep 7, 2011 | 08:27 AM
African Rapper's Avatar
9th Gear
My Mirrors
I have an 05 Tl and my mirrors do sometimes work and sometime it doesn't when I put my car in reverse. Anybody have any idea on wht I should do?
Old Sep 7, 2011 | 08:32 AM
SharksBreath's Avatar
BANNED
work? as in "tilt" when you're in reverse? is the toggle button on the left hand side of the steering column in the correct position (left or right)?
if you've ruled that out, it's the mirror actuator (motor) and needs to be replaced. if you're still under warranty, take it to the dealer and get it repaired. (common issue on 3G TL's)
if you're not under warranty, take it to the stealer and get raped.
Old Sep 7, 2011 | 08:46 AM
9th Gear
Its not the toggle button. How do I get it raped and Who or Wht is a stealer?
Old Sep 7, 2011 | 08:57 AM
combat mediC's Avatar
Stealer = stealership = dealership.
Raped = well you're a rapper so you know what that means.
Old Sep 7, 2011 | 09:02 AM
9th Gear
Lol ok ok i get now. I'm def jacking that lol.
Old Sep 7, 2011 | 09:04 AM
BANNED
ok so it's not the toggle button. check.
you get raped when you go to the stealership bc they are criminals and take all of your hard earned money.
are you under warranty my friend?
Old Sep 7, 2011 | 11:32 AM
Acura604's Avatar
2021 RDX A SPEC
fyi... service tip from acuraoemparts re: mirrors:
CAR CARE TIP: The electric motors in power mirrors can be damaged by blasting the mirrors with high-pressure water. When the water is aimed at the base of the mirror glass, the shape of the housing directs the water behind the glass, forcing it
past the motor vents and seals. Then it’s trapped in the motor housing, where it can corrode the motor in a very short time. (Acura ServiceNews, June 1993)
Old Sep 7, 2011 | 12:06 PM
9th Gear
No i'm not. Question:Your S Type Lip is one kit or did it come in pieces?
Old Sep 7, 2011 | 12:19 PM
BANNED
aspec kit includes a front lip, side skirts, and rear lip.
side skirts are a complete replacement, front/rear lip are add-on pieces to your existing bumpers.
AckTL05 is a vendor on this forum and can hook you up.
Old Sep 7, 2011 | 01:25 PM
9th Gear
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
