My driver side door lock will not lock or unlock
Old Nov 29, 2009 | 05:27 AM
deepblue626's Avatar
My driver side door lock will not lock or unlock with either the keyless remote or the lock button inside. All the others lock and unlock no problem, just the driver side won't. Any ideas on what could be making it stick?
Old Nov 29, 2009 | 09:31 AM
JnC's Avatar
JnC
Former Sponsor
It could be loose connection to the door lock actuator or worse you could have the motor inside the actuator gone bad.
part number 16 in the following illustration
http://oemacuraparts.com/partlocator...layCatalogid=0
Again, you wouldnt know for sure until you take the panel off and check for yourself.
Old Nov 29, 2009 | 09:37 AM
JnC's Avatar
JnC
Former Sponsor
By the way, you didnt mention it in your initial post but if you can lock and unlock with the key then all the linkage is fine and would be one more reason for me to suggest something wrong with the actuator.
Old Nov 29, 2009 | 11:01 AM
Bender's Avatar
Mine went bad as well. I just use my hand and key to lock and unlock. Pulling apart the door is a huge pain and manually locking it still triggers the alarm.
Old Nov 29, 2009 | 12:14 PM
yes, i can still ock and unlock with the key.
Old Nov 29, 2009 | 12:16 PM
JnC's Avatar
JnC
Former Sponsor
Neat, just replace the actuator then, it shouldnt be that hard if you know your way around a few basic tools.
Old Nov 29, 2009 | 12:48 PM
just token the panel off and checked. looks like the lock is trying to lock but it is not lucking or unlocking.
Old Nov 29, 2009 | 12:57 PM
i'm sure it should not be the loose connection to the door lock. so does that mean it is the actuator?
Old Nov 29, 2009 | 02:02 PM
JnC's Avatar
JnC
Former Sponsor
If the actuator is making some sort of noise but is not clicking/unclicking then it means that the motor inside the actuator is fine but the gear mechanism inside the actuator may be damaged.
See if you can disassemble the actuator and rectify the problem. Even if you can't fix it you can always get a replacement actuator.
I still cant believe how cheap the actuator is, $18 or so. My Lexus GS300 is known for having its lock actuators go bad but the replacement ones are $270 a piece Luckily you can cut open the actuator and replace the motor inside with a replacement motor made for RC cars, motors go for $10 a piece on ebay.
Old Nov 30, 2009 | 03:19 PM
now, the lock works but i need to wait for some time for lock after i unlock the car.
Old Jan 9, 2010 | 05:47 PM
the lock was working for few weeks until now it is not work. why sometime it works sometime it does not work?
Old Feb 22, 2010 | 07:26 PM
tupacboy's Avatar
same problem is happening to me today... how did u fix it?
Old Feb 22, 2010 | 08:55 PM
dbqtown's Avatar
I don't know if you live in a cold climate but i have that same problem but only in the winter when its really cold.
One morning going to start the car before work i noticed my front passenger door did not unlock. So i assumed the actuator went bad, I even called acura to price out a new actuator for me.
After sitting in the sun and warming up at work when i left is was working again. And it has happened more than once but when its not to cold it works fine.
I dont know if moisture is getting in somewhere and freezing something up but thats what it sounds like and for some reason when i lock the car and all the locks work the one that gets frozen makes a slight whining noise when it locks.
Old Feb 22, 2010 | 09:09 PM
Bender's Avatar
Just program it to not auto lock and use your key until you replace it.
Old Feb 27, 2010 | 04:29 AM
zeezz's Avatar
Team Anthracite Webmaster
you can buy this actuator part from a honda dealership. it will be slightly cheaper. replacement is not TOO hard if you have been tearing apart your car, but its going to be much cheaper than going to a shop. BE CAREFUL not to strip the three big screws/bolts holding in the strike area of the assembly.. on the door. you'll know what i mean. trust me, lesson learned...
Old Feb 28, 2010 | 10:45 PM
RyanCHICL's Avatar
#GOBULLS
Is there any first signs of the actuator going bad? I ask because my door looks are working but they sound kind of "sloppy" lately.
Old Feb 28, 2010 | 11:25 PM
pohljm's Avatar
Maybe some spray electronics contact cleaner into the actuator may help things?
Old Mar 1, 2010 | 10:29 PM
hofiveo's Avatar
The driver door may have a few more connectors to disconnect from backside of door panel, but it should still be pretty easy. You can buy a trim removal tool from Napa, Autozone, it looks like a screwdriver handle with a fork styly end that has a slight bend near the end.
https://acurazine.com/forums/3g-tl-problems-fixes-114/f-179-diy-pass-door-lock-actuator-replacement-w-pics-764241/
Old Mar 5, 2010 | 09:53 PM
sifuacura's Avatar
There's alot of asian in
this happened to me today too..really bad..maybe its a sign of the 3rd gen TL wear and tear?
Old Mar 6, 2010 | 11:48 PM
moukie4401's Avatar
My passenger door lock does it also. But it is always associated with rain or carwash...not cold.
Old Mar 12, 2010 | 09:04 PM
flouie's Avatar
My actuator went out and I'm trying to remove it but can't.
Is there something locking the 3 big screws that hold the whole assembly to the door? I can not get those big screws to even budge a little it feels like there were wielded to the door. I actually broke the handle off my big screwdriver trying to remove these.
Old Mar 18, 2010 | 05:10 PM
rcp's Avatar
rcp
just need to put more muscle into it.
Old May 9, 2010 | 07:28 PM
mchester's Avatar
It helps a lot to use an impact driver and a hammer. Seems extreme, but it works and won't mess up the machine screw heads. Torquing these when tightening is CRITICAL to your safety in the event of a crash as well. Make sure you do it right.
Old May 9, 2010 | 08:27 PM
Bender's Avatar
Use a ratchet with a breaker bar.
Old May 9, 2010 | 09:08 PM
mchester's Avatar
They are phillips head machine screws. Most folks won't have a ratchet bit that would fit well enough to loosen these. They are quite tight for phillips heads, 20 ft/lb I think, and need to be torqued equally tight when reinstalled. An impact driver is about $12 at Harbor Freight. Use the proper tool or you will be sorry. You apparently don't know what fasteners I am talking about or you would not make such an odd suggestion. The impact driver transfers the force properly to the fastener so that it won't strip. Using anything else will very likely strip the fastener and then things get expensive. Ummmm'k?
Old May 11, 2010 | 11:06 AM
Bender's Avatar
First of all, if you would have explained in detail the first time your reasoning behind your methods people wouldn't have still been scratching their heads. Second tell me how screws for the door actuator is critical to our safety.
By the way, you need a compressor to power the impact tool so you may as well go rent it if you even need to.
Old May 11, 2010 | 01:26 PM
mchester's Avatar
You are more ignorant than I first thought. I think the only person scratching their head is you, because you have no idea what is being discussed.
1st, you are thinking of an air powered impact gun/wrench. That is NOT what I said or meant. An impact driver is a hand tool that is struck with a hammer and tranfers that power into a sharp twisting motion. It is made specifically for uses just like this and it requires only a hammer and some common sense to use correctly. I'm sure most folks have this covered.
The reason torquing these 3 machine screws is critical, is becasue the door latch mechanism is held to the door by these same screws. If they come loose, the door could fly open without warning. That could be BAD. The actuator is attached to this assembly and is much more easily accessed once removed from the door. If you had ANY clue what was being discussed, you'd know this.
You read part of the post and thought "I've got all the answers", so you posted a half assed response that is totally wrong and can actually be dangerous. Think about the ramifications of your posts before you make them. YOU could help get someone hurt or even KILLED.
Old May 11, 2010 | 06:48 PM
Bender's Avatar
Finally, we shed some light about the exact procedure he is talking about. There is no need to be vague then act like an ass when someone questions you. Just explain it right the first time.
Old May 11, 2010 | 08:06 PM
Burnricers's Avatar
My passenger side actuator just went out the other day, warranty work = win!
Old May 12, 2010 | 06:02 AM
mchester's Avatar
Bender, if you notice, nobody that actually has the issue and knows what was being discussed was actually confused. It was just you... Sorry I was so rude, but folks that offer poor advice annoy me. If I could have edited the post, I would have, but it did not allow me to do so.
Old May 12, 2010 | 08:16 AM
Bender's Avatar
Just curious, has anyone died because they improperly installed their door actuator?
Old May 12, 2010 | 10:03 AM
ggesq's Avatar
Gentlemen, enough.
Old Jun 15, 2011 | 08:38 AM
Royik1157's Avatar
This happened to me yesterday. It was during a downpour and I had to drive over a massive puddle. And I'm slammed so I'm not sure if water went into the door or its just the actulator that went bad
Old Jan 11, 2013 | 04:47 PM
nwacurauser's Avatar
I am facing a similar issue - I have a two month old acura which I park in a sheleterd parking. On days with sub-zero temperatures my front passenger side door gets locked. It does not happen to any other doors - just one of the doors. We need to wait for atleast 5-10 mins drive around and then it gets unlocked - but it is very inconvenient . We took the model to the service station - the first time they sent us back saying it was probably cold, the second time they took the vehicle in and reportedly changed the actuator, but it happened again. I have never faced this issue with any of my older cars - Not expected out of the acura brand Any suggestions on what can be done ?
Old Jan 11, 2013 | 06:56 PM
DeathMetal's Avatar
Fearless DIY Guy
Guys, the switch is simply shot and has burnt out. There's no loose connection, no troubleshooting, it's simply DONE. All you need to do is purchase and replace a new one. The cost is about $24 from Tim, a sponsor and OEM dealer on this site. You're overthinking/spending too much time troubleshooting. $24 will rid you of your woes.
Old Jan 12, 2013 | 05:57 PM
dario18's Avatar
My front passenger door makes a weird rattle noise every time i lock/unlock it. Is it the actuator gone bad? That's what the dealer told me, he wants $50 to order it and $200 for labor. I'll just buy it online if it is
Old Jan 12, 2013 | 07:42 PM
DeathMetal's Avatar
Fearless DIY Guy
I'd pop the door panel off first to see if anything has come loose. It's only 4 screws.
Old Feb 13, 2015 | 03:52 PM
patpur's Avatar
Here's what I did. Went out the other day and the driver door lock wouldn't operate with the key fob. I have a 2005 tsx I bought for a daily driver. I yanked the button up an down for about a minute then soaked the lock mechanism with Power Lube. No more problem. Hopefully I wont have to replace the actuator.
Old Feb 13, 2015 | 04:24 PM
Turbonut's Avatar
5 1/2 year old thread, but replacement of the actuator isn't much of a job, just a little time consuming. Did ours last August.
Purchased from Acura on line, but they have one on ebay $10.29 free shipping. How good is it??????????
Old Oct 15, 2016 | 10:54 PM
Natalie2789's Avatar
My passenger window is messed up not sure exactly why but right now it has viscrips
It used to work fine n now it don't work at all the passenger window is being held shut with viscrips n can't roll down or up
