Mushy Brake
Mushy Brake
Hi all,
06 TL MT
I had my oil changed about a month ago brake pads checked out ok. The last week or so the brakes feel mushy and once in ahwile feel like the pedal is sinking. I pumped the pedal and its firm so it doesnt seem like the master cylinder is an issue. Could the change in temp. cause this (it cooled down about 20 degrees last week). I will check the master cylinder as well, but wondering how much the brake fluid flush should cost last quote I received was $120 from the dealer?
06 TL MT
Type-S AT & MT are the same brakes. EXACTLY the same.
Also ALL 2004 - 2006 MT are EXCATLY the same brakes as ALL 2007/2008 TL-S.
Stock thickness new = 0.98 inches.
- Front Discs TL - Ventilated, 11.8 in (300 mm) diameter; 1.1 in (28 mm) rotor thickness
- TL Type-S - Ventilated Brembo, 12.2 in (310 mm) diameter, 0.98 in (25 mm) rotor thickness
- Rear Discs Solid, 11.1 in (282 mm) diameter; 0.35 in (9 mm) rotor thickness
http://www.hondanews.com/channels/ac...specifications
From the 2004 Service Manual (remember brakes for ALL '07/'08 TL-S are the same as brakes for ALL '04-'06 MT):
https://acurazine.com/forums/3g-tl-2004-2008-93/tl-s-rotor-size-794029/
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
