Motor mounts
Old Sep 20, 2011 | 04:25 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Angry Motor mounts
So I noticing my front motor mount is going out.. I was searching for a DIY but no luck... on a scale 1-10 how hard is it to do .. Or should i take it to the shop... any sugguestions ???
Old Sep 20, 2011 | 05:18 PM
usmarinedelta's Avatar
Front is cake, you have to remove a fan though. I would rate it a 4. If you look straight down, it's four bolts on each corner, and one bolt through the center, then unplug the vac hose. However if one went out I'd check the others, rear is a pain but doable.
Old Sep 20, 2011 | 06:55 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
What did you use to lift the engine??? 3ton jack should do the job right ...
Old Sep 20, 2011 | 09:52 PM
SpiderX1016's Avatar
You don't need to remove the fan. Use a jack and a block of wood.
Usually it's the front and side mounts.
Old Sep 20, 2011 | 11:49 PM
Cochese's Avatar
Sabotage
Here you go. Just jumping into this myself.
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-99-03-front-engine-mount-replacement-734247/
Old Sep 21, 2011 | 12:45 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
aswesome, that’s what i was looking for…. I didn’t know it was the same as the older models i gotta get started on this by this weekend .. Thanks guys i even might do a new diy
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
