Motor mounts
HASTA LA VICTORIA'
Motor mounts
So I noticing my front motor mount is going out.. I was searching for a DIY but no luck... on a scale 1-10 how hard is it to do .. Or should i take it to the shop... any sugguestions ???
Front is cake, you have to remove a fan though. I would rate it a 4. If you look straight down, it's four bolts on each corner, and one bolt through the center, then unplug the vac hose. However if one went out I'd check the others, rear is a pain but doable.
cipdagr3at (09-20-2011)
cipdagr3at (09-21-2011)
HASTA LA VICTORIA'
aswesome, that’s what i was looking for…. I didn’t know it was the same as the older models i gotta get started on this by this weekend .. Thanks guys i even might do a new diy
xsilverhawkx
09-28-2015 06:51 PM
