Motor mount install
Old Sep 23, 2012 | 01:40 PM
oneway's Avatar
Motor mount install
I had come across a thread on how to install all the motor mounts with pics. I searched hi and low and can't find it anywhere. Can anyone help me find this?
Thank you,
Anthony
Old Sep 23, 2012 | 01:44 PM
IntactACK's Avatar
sub'd
Old Sep 23, 2012 | 02:37 PM
paperboy42190's Avatar
search... front and sides are easy. for the rear....if you need a DIY then dont bother doing it yourself
Old Sep 23, 2012 | 03:09 PM
JORTS's Avatar
Would it be obvious if my mounts needed replacing? My warranty is up in Dec and would live to get them replaced under warranty. I havent noticed and knocks or sounds to make me think my mounts need replacing. Thanks guys. Sorry for the tread steal
Old Sep 27, 2012 | 01:21 PM
IntactACK's Avatar
I'm thinking of upgrading mine, not because I think mine are bad but just for piece of mind and a stiffer setup.
Old Sep 18, 2013 | 06:43 AM
IntactACK's Avatar
Can anyone give me a heads up on what is required for the job? Just some previous experience tips and tricks if there is any?
Old Sep 18, 2013 | 07:01 AM
What's required? A bit of experience on cars. Not too hard it's pretty straight forward, very simple in concept just remove the bolts holding it, slightly raise the motor, and remove the mount
Old Sep 18, 2013 | 10:18 AM
IntactACK's Avatar
When doing timing belt and cams I believed I removed the power steering pump before taking the passenger side mount off though, I was just asking the severity of all the mounts but if its easy then I'll take your word for it!
Old Sep 18, 2013 | 10:23 AM
^i was about to poke fun...
can do cams but not motor mounts.
Old Sep 18, 2013 | 10:56 AM
Acura_Swag's Avatar
I got to replace all of mine aswell
Old Sep 18, 2013 | 11:16 AM
ez12a's Avatar
the overexplainer
In order of easiest to most difficult: Passenger side mount, front mount, rear mount.
You dont need to remove the p/s pump to get to the side mount (but with the work you were doing you had to do it anyway). I've done all motor mounts but the rear.
Old Sep 23, 2013 | 09:10 AM
punky's Avatar
I used this thread for the rear mount, which was the hardest.
https://acurazine.com/forums/showthr...=683990&page=2
Old Sep 23, 2013 | 09:13 AM
IntactACK's Avatar
Sometimes there is small tips and tricks that make life 100 times easier I just wasn't sure if we needed anything specific or if there was an easier way to get the rear mount done thats all, thanks though guys.
Feb 25, 2020 09:57 AM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
