More than a bad starter?
Old 05-17-2013 | 01:45 AM
jkopuffs's Avatar
with the key turned all the way i hear 1 click then dead silence. banged on the starter solenoid with a wrench and the car finally turned over. yesterday i got a new starter installed. but today i had the same problem, turned the key all the way and nothing. but the second try started the car. what seems to be the problem?
Old 05-17-2013 | 08:41 AM
Project_CLean's Avatar
MMkay.
Did you check your battery.....?
Old 05-17-2013 | 08:45 AM
MMkay.
Threads like these upset me. I'm curious to how you came to the conclusion that it was your starter?
Old 05-18-2013 | 03:09 AM
jkopuffs's Avatar
oops forgot to mention it... i typed up the scenario before this and accidently hit the back page ... battery is fine, went through 2 different place and both passed. terminals are clean and tight. battery was bought less than 1 year ago.
Old 05-18-2013 | 10:30 AM
carz0159's Avatar
check for wires with corrosion leading to the starter, battery. thats the next easiest and cheapest thing to do.
Old 05-18-2013 | 11:02 AM
ken255's Avatar
7th Gear
That's right. people tend to overlook the condition of terminal on the starter side. not only terminals, but also sometimes a rusty washer causes high voltage drop.
Old 05-18-2013 | 01:53 PM
MMkay.
Couldn't have put it better. Connections cause a major percentage of electrical problem!
Old 05-19-2013 | 05:43 AM
jkopuffs's Avatar
like i said guys, the first thing i checked was the battery. i took the cables off and cleaned the terminals. then i went ahead to replace the starter
Old 05-21-2013 | 03:43 PM
Enveee's Avatar
i have the same problem it only happens once in a while and i think it has to do with my starter as well but not 100% sure i try and start the car but it doesnt start then i turn it off and try it again then it works. sometimes when i come back into my car the navi code pops up so i think my car died out. what do you think is the problem?
Old 05-22-2013 | 08:38 AM
MMkay.
Any news jkopuffs?
Mike Pilipenko
03-26-2024 10:21 PM
07-16-2017 08:33 AM
Timmy18
10-17-2015 04:58 PM
agupta3224
09-22-2015 09:08 PM
Quick Reply: More than a bad starter?
