Moonroof Rattle?!
It took 2-3 trips to my Acura dealer. First time they pretended they didn't hear it. Second time they put felt or some sort of foam/sealant up in the shade/roof lining area and it didn't work. 3rd time they finally isolated that it was coming from where the shade and the interior lining of the roof meet but that they would have to rip the entire moonroof and half the roof apart to get to it and I was not prepared to do it. Sad to have to use furniture cushions on a expensive luxury car, like the TL, but it was a much cheaper/hassle free move then having Acura rip the roof apart and they probably would not solve the problem or even if they did, make a new problem by not putting it back together properly.
I'd suggest going to Home Depot or Lowes, and spend the 8-12 bucks on a small furniture cushion and put it up in there between the shade and interior roof lining so you can have piece of mind. I got one that matches pretty close to the taupe color so unless you stare at it, you don't notice it.
Sorry to be the bearer of bad news, but thats just the nature of the 3G TL rattles!
There is a rattle in the moonroof itself, which is a much easier fix, but it sounds like your having what I had which is not the actually moonroof, but you could take it into your Acura dealer and at least let them hear it and isolate it for you if you want! I personally don't think it is worse the hassle or trouble.
I figured there was nothing as I could to fix it, but I thought I would ask just in case!
My moonroof only started to rattle recently...ever since I got two subs in my trunk it started to rattle, I guess i shook something loose.
Not worth brining it to the Acura dealer, I am not giving them 90 dollars to tell me where the noise is....last time I told them where the problem was (my ignition rattles in my steering column) and they still refused to fix it, since the airbag was there....what a load of poop!
18psi
my moonroof rattle fix was to apply some white lithium grease (that you can buy at any car parts store) to the track where the shade slides back and forth. Put the grease on knife/screwdriver and apply it to the bottom part of the track from front to back. Open and close moonroof shade with your hand several times to spread the grease out. No more rattles for me
Addicted to boobs
I have an 08...Mine started doing the roof rattle about a week ago. Seems like its between the headliner and the roof in the front portion. Pain in the ass to find the culprit.
My 07 rattles like crazy from the headliner / moonroof area. It drives me crazy. I suspect the four plastic clips the headliner snaps into, just in front of the sunroof opening. The clips appear loose, brittle, and subject to rattle against the metal groove they slide in. My current plan is to put some Dynamat or adhesive felt into the area. But I'm open to other suggestions.
Also, check the upper console and around the mirrors. There are a few places where rattles can be induced by material transitions, wire connectors and loose fitting parts. A few small pieces of adhesive felt in these areas worked wonders.
08 MDX, 04 TL (sold)
Mine rattles too. So did the moonroof in my old Accord. So does the moonroof in my 08 MDX.
Anyway, there is a TSB about putting some felt up there. I just happened to look it up just yesterday and was considering trying this:
http://techinfo.honda.com/Rjanisis/pubs/SB/B04-034.PDF
Get some Shin-Etsu and lube the rubber before troubleshooting further. Read more here:
https://acurazine.com/forums/3g-tl-problems-fixes-114/why-shin-etsu-shiznit-745587/
Shin-Etsu is good on ALL of the rubber seals in the car and go a long way to quiet the rubber "chatter" when trying to isolate rattles. Give it a shot!
My '07 rattled like crazy from up there. Pull down the sunroof edge of the headliner closest to the rear and stick some two-sided tape in the gap. That rattle drove me nuts for 3 months until I chased it down.
I had a rattle where the "glass" met the actuall roof (the rubber frame seal against the metal of the roof. I took it this week to the dealer and didn't give it much hope on getting it fixed. But they fixed my rattle (07) - they applied what they called Honda Sunroof tape all around the edge of the metal - it feels like wax paper almost.
Something to try if you think it's the edge of the glass portion rubbing against the roof metal. I have one more noise beside the front speaker (going to replace anyhow). The last noise i have is the front driver's door glass is making noise i think where it meets the rubber seal about center on the top. I'll search to see if i can get it fixed or apply some silicone lubricant.
DF
DF
marcelft
07-10-2018 06:17 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
3GTLOwns
09-09-2015 09:51 PM
