Mirrors Wont Tilt
Old Jul 16, 2014 | 01:06 PM
BeattieWasHere's Avatar
Mirrors Wont Tilt
I seem to be having an intermittent problem with the mirrors not tilting when I put the car into reverse. The previous owner complained of this according to the maintenance records I got from Acura.. and their remedy to this was "Relinked the mirror memory"
Anyone have an idea how to do this?
Old Jul 16, 2014 | 01:09 PM
just to be sure; the mirror selector cannot be in the middle.
it either has to be Left or Right, but not both.
Old Jul 16, 2014 | 01:21 PM
Brock79's Avatar
I had this issue, all I did was reset my mirrors by adjusting them again and moving them around. I then set them where I needed them, put the car into reverse and it worked again with no issues.
Old Jul 16, 2014 | 02:14 PM
JTS97Z28's Avatar
The mirrors have always been a issue with these cars. Pretty every TL I have owned with exception of my current one so far, has had issues with the mirrors tilting in reverse. Its not that they wont do it, but they are jittery and twitchy if that makes sense. Its like the motors go back and forth and have no idea where to put the mirror, then it just stops. I noticed it does this more during colder months. Some people here say its because something needs to be lubed in there and then reset, but I don't buy that. To me it seems to be a motor or electrical issue. Your not alone on this, its a common issue with the TL...atleast the 07 and 08's.
Old Jul 16, 2014 | 02:16 PM
pbook4g5's Avatar
Yeah, mine works fine when I'm controlling it via the switch, but as soon as you hit reverse, it seems to hesitate and get stuck in a certain spot. The dealer told me it was a lubrication issue.
The only way I could see that being true is if the reverse switch actually sent less power to the mirror motor than the actual mirror switch. Seeing as thats highly unlikely, I really don't know what else the issue could be.
Mine's an 07 TL-s btw.
Old Jul 16, 2014 | 02:17 PM
have you guise tried to lube up the gears?
it takes away the noise and the jittery operation...
Old Jul 16, 2014 | 02:18 PM
JTS97Z28's Avatar
and thats why I don't buy the lucubrating fix. Simply because the mirrors work perfectly in regular mode. If it was a lubricating issue you would think the problem would effect the mirror movement regardless of the method controlling the movement. Its simply a shitty design that goes bad even on well maintained and low mileage cars.
Old Jul 16, 2014 | 02:36 PM
wilztlxs's Avatar
TLX-S
On my '04, when putting in Reverse, the mirrors would click all the time and sometimes it would randomly stop midway.
I took them apart and greased it with Shin-Etsu Grease. It has worked quiet and smooth with no issues since. When I had it apart, the grease from the factory was all in clumps.
Old Jul 16, 2014 | 03:00 PM
FloTime's Avatar
6th Gear
On my 08 Type S, I had the same issue. Clicking like they couldn't get all the way down when I went into reverse or if my GF used her key and they tried to move to her setting. I replaced the servos and haven't had an issue with either mirror since then. You can replace the mirror also but they are pricey. $400 a piece.
Old Jul 16, 2014 | 03:05 PM
I'll have to check and see if that makes a difference.
Agreed.
Old Jul 16, 2014 | 03:30 PM
JTS97Z28's Avatar
Well in those cases I guess it would be worth a shot. So how do you grease the thing? Do the mirrors pull right out? Then what and where gets greased? Even though my current Type S doesn't have the issue, it's just a matter of time before it starts to get those typical mirror issues.
Old Jul 16, 2014 | 03:44 PM
wilztlxs's Avatar
TLX-S
https://acurazine.com/forums/3g-tl-problems-fixes-114/3g-mirror-repair-pictures-3g-garage-e-045-a-832020/
Old Jul 16, 2014 | 11:28 PM
Taxandria's Avatar
My mirrors always go weird and wonky out of nowhere. I set everything just so and then I hear them whirring and clicking and the mirror starts going back and forth and then trying to turn itself too far in one direction so it sputters and twitches. It's been like that for years it stinks because it can happen when I'm driving which is dangerous I think. Mostly it has only happened when I am stationary and I haven't figured out the trigger. The car has "lived" in Canada (freezing cold) and in Texas (boiling hot) and does it in both locations. Meh
Old Jul 17, 2014 | 08:02 AM
SgtSir440's Avatar
I have had my 07 Type S for about a month now (got it with 27,000 miles) and I have noticed that my mirror will never tilt down when I go in reverse. However, when I shift out of reverse the mirror will tilt up and I will have to re-adjust it. It doesn't make any clicking noises or jittery movements and has no problems going down if I move it manually with the button. It doesn't really bother me that it doesn't go down automatically but it sure is annoying when I look over to merge and see nothing but the sky. I guess I'll try popping the mirror off and make sure everything has a good connection and that its greased up well. My parents 05 TL with 160k miles doesn't have any problems with the mirrors.
Old Jul 17, 2014 | 08:08 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
I had both of mine replaced Tuesday under warranty. Same symptoms as pretty much everyone else has mentioned. Thank You extended warranty.
Old Jul 17, 2014 | 09:32 PM
Tonywp75's Avatar
Dont Touch My Car !!!
Had the same issue for off and on, after the fix above it working perfectly now. Give it a try, easy DIY just be careful when removing. Takes about 5-10 min for the first mirror then the 2nd one is a breeze since you will know how to take the mirror off.
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
STC
Sep 23, 2015 04:36 PM
