Memory retention after battery disconnect?
Old Nov 11, 2009 | 07:05 PM
acuratelyquick's Avatar
The battery terminals on my TL are heavily corroded and I was going to clean them up. However, I was wondering what I will need to reset/program. I know I will have to enter the radio theft code (I have that). What else will be blanked?
Radio station presets?
Hands free phone book?
Homelink?
Old Nov 11, 2009 | 08:31 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
I'm not positive, but if you have nav - you will need the code for it as well as the radio.
Old Nov 11, 2009 | 09:17 PM
nfnsquared's Avatar
Get one of these and a 9-volt battery and you won't need to do a thing:
Memory saver
Old Nov 11, 2009 | 10:18 PM
LaCostaRacer's Avatar
^ or if you have a 12v battery power source with cigarette plug you can use that- you'll want to turn the ignition on. I did this when replacing my battery and everything worked well- I could even listen to the car stereo while doing the replacement which was another benefit.
Old Nov 12, 2009 | 07:03 AM
SouthernBoy's Avatar
Registered Member
This all assumes you have Nav.
You will loose very few presets. You won't loose your radio or seat and settings, for example. You may want to check your "Sound" settings (fade, balance, bass and treble).. I don't recall it those are lost. You will need your codes so have them handy before you remove your battery.
Old Nov 12, 2009 | 06:02 PM
dhong87's Avatar
when i used to work at a stereo shop, I would leave the car running to prevent any lost presets. Im not 100% sure if this would work on a TL though, worth a try =)
Old Nov 16, 2009 | 01:42 PM
AndrewA's Avatar
i had to do this yesterday and it turns out the corrosion got so bad, it busted the positive battery terminal. PITA!
Old Nov 19, 2009 | 02:39 PM
I cleaned the battery posts last night. I only lost the seat memory and had to reenter the radio code.
Stereo presets, homelink, and bluetooth settings were not lost.
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
ceb
ILX
Sep 27, 2015 10:56 AM
