Low Voltage battery help!!!
Old Nov 21, 2009 | 12:03 AM
tonyatkayak's Avatar
I am getting these two messages and I don't know exactly what this mean. I don't want to take it to the dealer already.. oh man.. new car and probs already.
Old Nov 21, 2009 | 01:03 AM
01tl4tl's Avatar
its new to you - a CPO car?- or its warranty still somehow?
go to autozone or similar parts store for a FREE battery and charging system test
A lot of gen3 go thru batteries in 2-3 years- its hot inside the engine area and lots of electrical demand just to operate the car
When voltage is low the sensors for things dont work right and the car runs bad
and gives warnings
those acura batteries are not the best sold- can do better with a costco for sure or many auto parts store brands are fine-
Old Nov 21, 2009 | 01:10 AM
and gives warnings
it's a CPO car and I got the extended warrenty but the battery was just replaced 14 months ago according to carfax.
I'll try hitting up a local store to ask them to check my battery. I'm just afraid it's not the battery and it's something more. ahh..
Old Nov 25, 2009 | 12:27 AM
HoolaTL-S's Avatar
oh man, thank god i found this thread, i thought i was the only one having this problem , i mean, it was driving me insane man, ok, it all happened when i got my car back from my mechanics for the 30k mile service, those 2 messages showed up on the nav screen, and could not be deleted , i took it back to the mechanics and they tested the battery and the voltage everything , still couldn''t find the cause, but tomorrow i am going back there and they ll put a new battery in see if it takes care of it , ...
Old Nov 25, 2009 | 04:16 AM
YeuEmMaiMai's Avatar
does the message go away once the car has been running a while? I would check alternator output
Old Nov 25, 2009 | 10:45 AM
let me know what's going on and if they fixed it. I made an appt to the dealership next monday. Ill update you when I find out also.
Old Jan 21, 2011 | 02:52 PM
skplex's Avatar
Any updates to the cause and solution of this?
Thanks.
Old Jan 26, 2012 | 09:39 PM
Djflavormix's Avatar
hey guys i am having the same problem !!!!!plz post if the problems work by changing the battery
Old Jan 26, 2012 | 11:39 PM
Pat04TL's Avatar
Cheapest route is to take your battery and alternator into Autozone and get them tested for free. With a "low voltage" indicator, I'd start with a multi-meter voltage check. Roughly 12.8V with engine off, and 14.3V with engine on. (If it's 12.8ish V with engine on, then the alternator isn't doing it's job.) I think I'd try a new battery if it's at least 3 yrs old (or at least temporarily borrow a decent one for troubleshooting purposes). Good luck and let us know how it turns out.
Old Aug 29, 2012 | 03:26 PM
jeeva86's Avatar
'08 TL-S 6MT
Hey guys, my battery was drained overnight by my aftermarket amp because the installer failed(see https://acurazine.com/forums/showpos...1&postcount=21). I disconnected the power wire that runs to the amp at the battery and taped it shut. Anyways, I used a multimeter to measure the voltage this morning and it shows 14V, upon start it's at 21V. Isn't this ridiculously high??!
Amp was placed Sunday, needed a jump start the next day, drove home for 30 mins and I've been able to start the car since but I can hear the starter struggle. It's not a crisp start so the battery definitely isn't fully charged right? Am I using my multimeter wrong? Anyone know where I can measure the alternator output? pics?
Old Aug 30, 2012 | 11:15 AM
jeeva86's Avatar
'08 TL-S 6MT
Ok, there is something is wrong with my multimeter. It read 18V on the accord at idle, so I'm guessing there's a +6V that I have to account for. I'm guessing the true voltage on my battery is then about 8V which explains the struggling noise the starter makes upon starting the car. Partsource charges the battery for free .
Old Apr 29, 2017 | 08:16 PM
davidm65's Avatar
I am having the same issue. I have a new alternator and battery. after each replacement the issue went away for about 3 weeks and came back. the problem does happen when the car starts up, but when it been running for a 1 hr or better.
08KBP_VA
Oct 22, 2019 01:55 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
Rcelestino93
Sep 23, 2015 10:01 PM
