Low pressure in brake pedal
Old 03-21-2011, 12:35 PM
Sandals's Avatar
So I push the brake pedal down and at around 50% I start to feel the brakes kick in. Last weekend I bleed the brakes and topped off the brake fluid reservoir. But it only improved very slightly. I figured there was some air in the line since the fluid was a littke bit below the max limit. My question is do I need to remove all of the old fluid from the lines and reservoir and what is the best way to go about it.
Old 03-21-2011, 12:39 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
First, my suggestion would be to rebleed the lines, and of course, get all of the old fluid out. You only need 2 bottles of fluid to do this. I think that would fix your issue.
Although you can do this yourself, it is much easier to properly bleed your brakes if you have someone else there to help you do it. If you don't want to do it yourself, go to an indy shop and pay for it.
Old 03-21-2011, 03:43 PM
Sandals's Avatar
Thanks. I will have my brother help me
Old 03-21-2011, 05:21 PM
the overexplainer
ez12a's Avatar
just a heads up, it's pretty much impossible to get all of the old fluid out with just 2 bottles. I went from a disgusting black to a shade of amber. Used both bottles, have a bit left in the 2nd for emergencies and is in my trunk. didnt feel comfortable bleeding it with barely any fluid left in the bottle.
You'll get a good amount of new fluid in mixed with some of the old, but it's a lot better than just running dirty old fluid. Good luck.
Old 03-29-2011, 04:55 PM
Sandals's Avatar
So i bought the 1qt of brake fluid from acura and went about bleeding the brakes. Just so I have this right this is what I did, take off the front drivers' side wheel then open the nipple have someone in the car push down on the pedal then close nipple and repeat. I did this to the front drivers side, front pass side, rear drivers side, then rear pass side in that order.
The pedal feel has not changed much, the color of the fluid in the reservoir went from black to light clear gray.
what am I doing wrong?
Old 03-29-2011, 11:25 PM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
Wrong order. F DRVR, f psnger, r psnger, r drvr. Are you MT? If so, did you bleed both outboard and inboard nipples? Read this thread:
https://acurazine.com/forums/3g-tl-2004-2008-93/brake-fluid-change-696162/
Old 03-30-2011, 04:48 AM
SpiderX1016's Avatar
Close the bleeder screw > pump brake pedal a few times and hold the pedal > open bleeder screw > close bleeder screw > release pedal and repeat
What kind of brake fluid are you using?
Old 03-30-2011, 04:32 PM
Sandals's Avatar
I used oem fluid. I will try again this weekend.
Old 03-30-2011, 04:37 PM
Sandals's Avatar
I have an automatic so I thought I only have 1 nipple.
Old 03-31-2011, 02:06 PM
invalidalias's Avatar
brakes
Brake Pedal is low and feels soft
TSB 07-041 VSA Modulator Conrol unit
its the strange box with brake lines coming out of it behind ps resorvoir
Old 04-04-2011, 01:01 PM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
get this checked... i had this problem a few yrs ago where the VSA was faulty and pumping air into the brake lines... it was covered under warranty...
Blakura even crashed his car because of this problem when his brakes suddenly locked up mid turn...
Old 09-07-2014, 11:48 PM
EM2typeflex's Avatar
Need to get the vsa unit checked, and thanks for,the jnfo Kamlung, ran into a member who crashed his car because of this which was reference in another thread.
Old 09-08-2014, 07:29 AM
YeuEmMaiMai's Avatar
this:
you can buy a plastic weed killer sprayer and a generic brake reservoir cap and make your own pressurized bleeder.
1. drill hole in side of container near the bottom
2. thread in a brass hose fitting
3. do the same to the cap for the brake fluid drill a hole and add a brass hose fitting
4. run hose from sprayer to cap
then you can add brake fluid to that screw the cap onto the fluid reservoir and pump it up go around to each caliper and open the bleeder until fresh fluid comes out.
Old 09-08-2014, 01:40 PM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Old 10-01-2014, 06:09 PM
Update!
My VSA /ABS was the problem. BE SURE TO GET THE SAME YEAR AND TRANSMISSION AS YOUR CAR.
Old 04-09-2019, 10:30 AM
capper's Avatar
Originally Posted by EM2typeflex
Update!
How much was the replacement? Isn't an expensive part? How did they diagnose it?
Old 04-09-2019, 11:03 AM
Received 8,597 Likes on 6,640 Posts
Originally Posted by Majofo
Old 04-09-2019, 11:25 AM
Received 16,260 Likes on 11,971 Posts
air in the lines? cant figure out where the air is coming from??? possibly the ABS modulator.
Grab one from a junk yard; dont pay retail for it
Old 04-18-2019, 03:36 PM
capper's Avatar
Replaced the ABS modulator from a junk yard. Didn't change anything unfortunately. Going to bleed again! Good god!
Old 04-18-2019, 03:41 PM
Well don't just start throwing parts at it.. DId you replace brakes recently? Check all the lines and make sure the bleeder valves are closed and there's no break anywhere.
Old 04-18-2019, 03:44 PM
Majofo's Avatar
Looks like it's time to make sure the insurance policy is up to date
Old 04-18-2019, 03:49 PM
capper's Avatar
Modulator was the last resort. Brakes were replaced recently along with the master cylinder. No leaks
Old 04-18-2019, 06:38 PM
capper's Avatar
Should I replace the master cylinder again just in case it was defective?
mada51589
05-03-2022 08:54 PM
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
pgeorg
3G RLX (2013+)
33
09-16-2015 07:40 PM
Ny1718
09-11-2015 09:21 AM
k6biv
09-10-2015 06:37 PM
Quick Reply: Low pressure in brake pedal
