Losing coolant
Losing coolant
Im loosing coolant very slowly, I haven't added any since Ive had it, when I bought the car it was full, ive had it for about 8 months, and the coolant is just below the minimum mark now, any reason why this would happen, I haven't noticed any leaks.
Look at the small rubber hose connecting the radiator cap to the tank.
typically that's where it would leak from. You'll see small white residue built up under / around the hose and top of radiator.
If all looks clean,
Maybe the overflow tank was filled without topping off the radiator when it was purchased?
if no leaks are found, probably the overfill tank was topped off but not the radiator when you purchased it.
If all looks clean,
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
us285126
10-02-2015 02:03 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
