Loose Driver Window
Old Nov 19, 2019 | 05:55 PM
jimmyfu's Avatar
Loose Driver Window
Has anyone kind of had a loose driver window? It works fine going up and down, but whenever I push the button to go down and let go, if I push down on the window itself it moves maybe another half inch lower. Wondering if I need to tighten something on the window itself?
Old Nov 20, 2019 | 09:53 AM
take the door panel off and check the regulator.
Old Nov 20, 2019 | 07:24 PM
Marcos Luis's Avatar
4th Gear
Agreed. Two screws attach the bottom of the window to the regulator slide. Make sure they are secure and the pulley line itself isn't loose.
Also check the window slides for tacky or dry lubrication. Some WD40 specialist silicone lubricant can ungunk window movement.
cgilley
Aug 2, 2015 08:56 PM
PrissyJayne
Jul 22, 2011 10:05 AM
ZeroCL
Jun 11, 2007 10:48 PM
kmc0929
Oct 4, 2006 12:30 AM
shaolin
Jul 1, 2003 10:48 PM
