Lights out on dash
Old Mar 31, 2011 | 10:30 PM
onezfast1's Avatar
Lights out on dash
I just bought a 05 Tl w/navi to replace my 99 tl with 260,000 miles. I have had the car for about a mounth and a half now. I was looking at the driver side of the nav screen and where the controls are for the climate control the light is out. Is there a way to fix or should I just let it be?
Old Apr 1, 2011 | 08:04 AM
invalidalias's Avatar
are you talking about the illumination lights that light up the buttons?
Old Apr 1, 2011 | 05:59 PM
onezfast1's Avatar
yes
Old Apr 1, 2011 | 06:26 PM
guitarplayer16's Avatar
It's an easy fix.
Buy the bulbs, and replace them.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Apr 1, 2011 | 09:09 PM
LostSol's Avatar
Chapter Leader (Central Florida)
I just did this the other day, had 2 lights out, the bulbs are only about 4-5 a piece.
You do have to take apart most of the center console/dash so its not super easy, but its not impossible, but one word of warning for you: I replaced 2 bulbs, and the next day another went out. DO THEM ALL!! lol you dont want to experience the feeling i had when that last one went out after all of that work.
Old Apr 1, 2011 | 11:36 PM
cjTL's Avatar
I'm Craig
I replace the same ones in my car last summer, it's a pain in the ass to do, so replace them all. If you've never taken apart your interior, set aside an a pretty good chunk of time. Its not hard, just takes a while.
Old Apr 2, 2011 | 11:04 AM
onezfast1's Avatar
thanks guys, I will get this done very soon
Old Apr 2, 2011 | 11:08 AM
LostSol's Avatar
By the way, youll need this:
https://acurazine.com/forums/3g-tl-2004-2008-93/those-who-have-service-manual-i-need-help-3g-garage-f-052-a-557238/
Old Apr 2, 2011 | 02:24 PM
DMZ's Avatar
DMZ
Head a da Family
Given the age of the car and the amount of work required to get to those damn bulbs, it only makes sense.
I've yet to replace my Temp Up/Down on the driver's side, the red triangle hazard flasher, and about 4 more on the steering wheel where the same thing goes, if you're gonna take it all apart, DO THEM ALL!
Old Apr 2, 2011 | 07:52 PM
onezfast1's Avatar
hey thanks alot!
Old Aug 11, 2011 | 12:45 PM
04_6SPEEDTL's Avatar
I mod my car in
Couldn't agree more with the "do them all". Its fairly easy to get in there you just have to be careful that you dont damage any of the parts you take off. I had just two bulbs out on the bottom of the navi and i replaced all 4 bulbs. I put everything back together & as luck would have it the temp bulb went out. Getting the other bulbs today
Old Aug 11, 2011 | 02:01 PM
swoosh's Avatar
takin care of Business in
Since you are doing all the lights (I would highly recommend that)....you will need the following:
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-0-retrofit-oem-bayonet-housings-led-747846/ - Part 0 Retrofit of OE Bayonet Housings with an LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-i-map-light-console-746609/ - Part 1 Map Light Console
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-ii-rear-door-window-switch-w-handle-leds-746947/ - Part 2 Rear Door Window Switch w/ Handle LEDs
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-iii-steering-wheel-leds-audio-cruise-modules-763640/ - Part 3 Steering Wheel LEDs (Audio and Cruise Modules)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-iii-steering-wheel-746972/ - Part 3 Overview
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-iv-center-vents-747870/ - Part 4 Center Vents
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-v-cluster-console-easiest-bunch-747874/ - Part 5 Cluster Console (EASIEST OF THE BUNCH!)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-vi-front-passenger-door-w-rl-door-handle-led-750657/ - Part 6 Front Passenger Door w/ RL Door-Handle LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-vii-front-driver-door-w-rl-door-handle-led-750671/ - Part 7: Front Driver Door w/ RL Door-Handle LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-viii-knee-panel-lights-vsa-mirror-etc-750880/ - Part 8: Knee Panel Lights (VSA, Mirror, etc)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-ix-heated-seat-switches-755070/ - Part 9: Heated Seat Switches
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-x-cupholder-illumination-755388/ - Part 10: Cupholder Illumination!
Old Mar 18, 2013 | 06:54 PM
THEReeM718's Avatar
Type Sour
It's true a few bulbs go out and I replaced them. Next day my seat warmer bulb was out... going tomorrow to purchase more bulbs again. Replace them all.
Old May 15, 2017 | 09:30 PM
JDMalliance's Avatar
5th Gear
this mod is a pain dealing with all the work you must do to get to the bulbs. It is worth it. But put time aside when you start. I did them all on the Nav and climate control buttons, I gotta go back and finish.
mada51589
Jan 9, 2025 04:40 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Rob144
Sep 21, 2015 08:18 AM
Greengecko
Sep 16, 2015 08:19 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
