Lights on Dash After Battery Change
you need a scan tool that can read and erase abs trouble codes. Once the ABS codes are erased you may still have just the Orange triangle. If the orange triangle remains then you will need to do a sensor neutral position memorization. IF you need the prodedure let me know and I will type it out for you.
I had that too this past Summer. My battery was too weak to start the car n a very hot day. Got a jump from a tow truck and all of those same lights stayed on. I drove it to the dealership and after I restarted the engine it was normal again. The dealership still looked the car over, but found no problem.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
HeloDown
09-08-2015 06:51 PM
