Left Blinker/Marker light
Old Nov 7, 2010 | 05:43 PM
Stryker908's Avatar
9th Gear
Hi All-
Just picked up a 2005 TL, and when I got it home I noticed that the left front blinker/marker light is not working. The Blinker works fine, but the "running light" is off, just from looking it looks like there is only one bulb in there. If the light is working for "signaling" but not "running" is there a fuse to check? Or is there actually a second bulb in there ?
Old Nov 7, 2010 | 08:45 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Originally Posted by Stryker908
Hi All-
Replace the bulb.
They are called "Dual filament" bulbs.
You can see the dual filament part on this bulb. What happens is one of the "coil bridges" falls apart which cause that side not to work.
Old Nov 8, 2010 | 02:25 PM
Stryker908's Avatar
9th Gear
Originally Posted by 04WDPSeDaN
Replace the bulb.
Thanks for the info.
Anybody got a replacement guide? From what I've seen it looks like you remove part of the wheel well liner, is that right ?
Old Nov 8, 2010 | 05:27 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Yes that is correct. You take use a butter knife to do this job.
So because it's the left front you turn your wheel all the way to the right.
This allows you the space needed to work.
With the butter knife you pry back the plastic inner wheel lining, easy spot would be where the bumper meets the fender. You then pull and fold the liner to the side and shove your hand behind the headlight. You will feel the connector and the light bulb socket. You twist the socket to unlock from it's position on the headlight and pull back. You may not have enough room to pull the entire socket and bulb out so disconnect the plug. It shouldn't take no more than 5 mins and that's being very generous.
Old Nov 9, 2010 | 09:58 AM
Stryker908's Avatar
9th Gear
Thank you for your help-
In case anybody else stumbles across this thread with a similar question, the info can be found on page 214 of the owners manual
https://techinfo.honda.com/rjanisis/...404O00211B.pdf
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
Ny1718
Sep 11, 2015 09:21 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
