Leather/pleather door panels
Old 08-19-2011 | 09:20 PM
cinobyte's Avatar
so on both my back door one is worse than the other. The leather\pleather is coming loose. I would guess it was glued then tucked from the factory. is the best method of repair to 3M glue it then re tuck it? i can post pics if need be
Old 08-20-2011 | 09:38 AM
clsbuyer's Avatar
i believe i have the same issue you are referring to on my right front door area. Havent dont anything about yet
Old 08-20-2011 | 09:45 AM
77donovan77's Avatar
....just dancing in
This must be a common problem, my passenger door leather lining is separating from its position as well, I just keep tucking it back in place, will get around to gluing it in place permanently. Just curious is your interior black?
Old 08-20-2011 | 09:48 AM
cinobyte's Avatar
Yep its black probably melted the glue it gets so hot in the car some times
Old 08-21-2011 | 12:03 PM
cinobyte's Avatar
So no suggestions on how to fix this?
Old 08-21-2011 | 10:50 PM
cinobyte's Avatar
LOL you guys suck.... My issue with just shooting some 3m glue back there and re tucking is I am afraid it will push through the perforations and make a mess or even be seen once it dries
Old 08-22-2011 | 01:38 AM
csmeance's Avatar
the 3M glue is a very light spray and it shouldn't go through the holes and such. Clean the area up and spray the panel and simply place the leather on top and tuck! Your done!
chasingthecool
03-09-2017 05:16 PM
soupi
14
11-15-2015 11:15 AM
xsilverhawkx
09-28-2015 06:51 PM
Quick Reply: Leather/pleather door panels
