Leaking Coolant.. Help please!
Old Feb 27, 2018 | 03:30 PM
algonquinloon's Avatar
Hello All,
I discovered last night that all of my coolant had leaked onto the garage floor (2008 TL AT). I pulled off the cowling underneath because I could see no coolant on either side of the radiator on the fins or around the bottom seam all around (looking from the top down). The leak is very fast coming out just under the bottom radiator hose. But I used a mirror to view there and no coolant is on the hose or anywhere on the black plastic bottom. See pic (forgive the pic size/placement.. first time and in a hurry). It seems that the fluid is coming out from the front of the radiator opposite the lower hose. Is there another connection on that side that could have failed? I was hoping not to have to pull the whole radiator out.
Also, the aluminum power steering elbow that screws in just left of the lower hose was totally loose and I have that off. What sort of washer needs to be placed on that? The outer stainless/aluminum washer is fine but the one that goes up against the black plastic looks like it was steel and corroded to powder. That's why the elbow was loose.
Thanks for any thoughts. This is the first failure I've had in nine years!
Todd
Old Feb 28, 2018 | 12:00 AM
I finally solved this issue by pouring in distilled water and watching it leak out below a few more times. The water was exiting around the female ATF connector inside the radiator bottom. When tightened the ATF elbow washer seals the gap around the female connector hole. I'm starting a new thread on this because the female threads are totally stripped due to the old washer corroding to powder and allowing the elbow to vibrate side-to-side. This is likely to happen for many especially up north here with salted winter roads. I do not see a way to reattach the elbow without buying a new radiator.. so I'm rehearsing expletives repeatedly in my brain.
Old Feb 28, 2018 | 12:40 AM
Is Helicoil an option?
I hope one of the Pro's here can help me out of a jam. I discovered today that the female threads inside my radiator bottom are totally stripped and the ATF cooling hose elbow will not tighten. I can hardly believe that this means I need to replace the radiator. Can I use a helicoil to get this in or is there another option I am not thinking of? Thanks for any ideas.
Female connector threads totally stripped
ATF hose elbow
Old Feb 28, 2018 | 04:57 AM
teh CL's Avatar
Seeing as the rad has to come out to to fix this you might as well take the opportunity to replace it & do a coolant change depending on mileage.
Old Feb 28, 2018 | 07:30 AM
horseshoez's Avatar
Latent car nut
To save a cylinder head I would opt for a helicoil, to save a radiator, no, I wouldn't bother. Said another way, time for a new radiator.
Thinking back, I believe I recently ran across a thread which said Rock Auto has a good price on OEM radiators. You might want to check them out.
Old Feb 28, 2018 | 08:20 AM
rockauto or amazon for a DENSO radiator. It can be had for ~100 bucks. DENSO is the OEM supplier for our car. Don't bother helicoiling that.
Old Feb 28, 2018 | 08:39 AM
I've merged your two threads regarding leaking coolant and helicoiling, they're the same issue and it'll help to have context.
Old Feb 28, 2018 | 03:36 PM
quantum7's Avatar
Just do the radiator....not a bad job. Denso can be had for a reasonable price and the job is pretty straightforward.
Old Feb 28, 2018 | 04:22 PM
Thanks all. I ordered the Denso from RockAuto for $113. Should have looked at Amazon. Seems like a lot of RA parts come out of California so I coughed up another $30 for 2-Day FedEx. Cant wait until next Tuesday for it. I found 2 gallons of premixed PENTOFROST by Pentosin blue coolant at local CarQuest. It's gonna have to do cuz nearest dealer is 40 miles away. Will replace thermostat as well.
Old Feb 28, 2018 | 08:17 PM
svtmedic's Avatar
I did the Pento frost blue When I did my 105 service. The pentosin blue is good stuff and formulated for the Honda/Acura line. If your concerned go to the pentofrost web site. It tells you what models it's good to use it on. With our cars they are concerned about silicates and that sort of thing. It's like my bmw, same concerns. On the bmw my thermostat is like 550 at bmw and the part is like 235 or some crap. The kicker is the whole cooling system is plastic and is the highest failure point on the break my wallet. What a driver car though. I think it's like the sr71 blackbird, sitting on ground she leaks all kinds of goodness, but at altitude she tightens up.
Old Mar 1, 2018 | 10:01 AM
amazon also sells Honda Type 2 Blue Coolant
luan_luan
1G TL Problems & Fixes
Apr 4, 2017 09:48 PM
eTL01
Apr 16, 2015 07:47 PM
Flyest Ever
Dec 6, 2014 09:59 AM
Jsouthern
Mar 16, 2014 01:49 PM
RTizzo
2G CL Problems & Fixes
May 19, 2009 02:34 AM
