Coolant Leaking--HELP!
Old Mar 16, 2014 | 09:34 AM
Jsouthern's Avatar
I have a 2006 TL and recently had the timing belt service done along with the thermostat and coolant flush. I just noticed that I have a coolant leak, more so when the a/c is on. It is dripping under the drivers side tire. I plan to take it back to the shop to have them look at it but until then, does anyone have any ideas what it could be?
Old Mar 16, 2014 | 09:55 AM
EvilVirus's Avatar
Check your hoses i.e. upper and lower hoses and the ac hoses. If you are taking in very soon then just check the fluid level until then.
Old Mar 16, 2014 | 11:40 AM
Canadian3GTL's Avatar
Keep your fluid topped up and take it to the shop, tell them the situation and that you have been topping it up (if it is in fact low) and get them to pressurize the system and check for leaks. If it's a drip when the a/c is on, are you sure it's coolant and not water dropping from the evaporator core?
Old Mar 16, 2014 | 12:25 PM
pohljm's Avatar
ac condensate
Old Mar 16, 2014 | 01:23 PM
I hate cars's Avatar
Originally Posted by pohljm
ac condensate
Lol. What I was thinking too.
Old Mar 16, 2014 | 01:49 PM
Jsouthern's Avatar
I have had to add coolant just a week ago so I know that it is the coolant. Def not the a/c condensate.
cycdaniel
Dec 17, 2019 10:58 AM
merc009
Jan 27, 2016 10:34 AM
LeVeL
Oct 18, 2015 04:19 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
